10KW is amazine... isnt it? what did you use for the coil windings to generate the power?
Quote10KW is amazine... isnt it? what did you use for the coil windings to generate the power?10kw is about 14hp, the generator appears to be a manufactured unit.
Nice setup but I don't think I have ever seen a more rusty engine!_________________Its mostly grease,I spent alot of time scrubbing it down.Took it down in steps,day by day,till i could see bare metal.Ill have the block back soon from the shop with 3rd oversize and blueprinted via magnaflux.Does anyone know why the text extends so far?What am i doing wrong here?
there must be a way to control that thing with the governor... i'd say calibrate the pump to cut fueling @ around 1800-2000 rpm. then basically have two modes. idle, and 'load' whereas load is full fuel travel. rpm stays at 1800 because any sign of drop in rpm, more fuel is injected to hold that rpm... a very large amount of fuel can be injected to hold that rpm :twisted:
i like how this was designed... keeping the gearbox to increase efficiency
