Author Topic: Locking Tools for TB change?  (Read 3494 times)
January 25, 2008, 06:02:18 am
nokivasara
  • 115
« on: January 25, 2008, 06:02:18 am »
I plan on changing the timing belt on our Golf TDI, engine code AGR.
Iīm making my own tools 'cause I canīt find a shop that sells them here in Sweden  :evil:
 I already have made a locking tool for the camshaft, so thatīs sorted.
Whatīs the diameter of the locking pin for the IP? And how long does it need to be?
Caddy 1.6N/A pushing 400 000km and going strong!
Reply #1January 25, 2008, 06:38:16 am
KTMAuto
  • 20
    • http://KTMAuto.com
« Reply #1 on: January 25, 2008, 06:38:16 am »
Just use drill bit, piece of round stock.  I usually find some thing that fits.  People get to crazy about this.
1981 Rabbit truck 1.6t, t3, GTD, Caged
1991 Jetta 2-door 1.6t, t3,
2001 Jetta TDI, Kerma 18-56, 502's, Kerma Q-load
Reply #2January 25, 2008, 06:43:10 am
nokivasara
  • 115
« Reply #2 on: January 25, 2008, 06:43:10 am »
I know, some people thinks it like brain surgery  :roll:
You donīt happen to know the diam of the drill you use? Just to be sure I have something to lock it with when I start removing things, on a AGR the coolant reservoir, PS-reservoir, IC-piping and the fuel hoses are on the timing belt side...Not to mention you have to remove a engine mount :lol:
Reply #3February 01, 2008, 12:48:40 pm
KTMAuto
  • 20
« Reply #3 on: February 01, 2008, 12:48:40 pm »
15/64 th
Reply #4February 02, 2008, 01:34:40 am
nokivasara
  • 115
« Reply #4 on: February 02, 2008, 01:34:40 am »
Thanks, Iīve already changed the TB.
* I used a 6mm drill bit for the IP
* a 4mm thick angle iron (aluminium actually) for the cam
* nothing for the crank.
I didnīt have anything to pull the sprocket with so I drilled a hole in the plastic rear TB cover and used a punch and a hammer to get it off the cam.
Older VWīs has that hole to begin with, the plastic cover is from A4-body and up.
Reply #5February 09, 2008, 10:12:41 pm
hillfolk'r
  • 1532
« Reply #5 on: February 09, 2008, 10:12:41 pm »
it wont help now,but try this next time
i used to use a 7/16 deep 1/4 drive craftsman socket,it worked great on my old 1.6's,and now my tdi-m
i do have the correct tool though
try goin thru a stack of sockets and see what works
actually do they have sears craftsman tools overseas? :oops:
Throttle cables ftw
