General Information
General
re-use head bolts?
Topic: re-use head bolts? (Read 10345 times)
January 24, 2008, 03:33:09 pm
Baselyne
re-use head bolts?
January 24, 2008, 03:33:09 pm »
I was wondering If it would be possible to get by re-using a set of head bolts 1 time only....
I know they say to relpace them but would you get by with a used once set?
Probubley not because it'ssssstretch type...correct?
January 24, 2008, 04:15:28 pm
Slave2School
re-use head bolts?
January 24, 2008, 04:15:28 pm »
I wouldn't risk having to redo a job because of the head bolts causing a head gasket leak....but they probably will work. Each time you use them and torque to vw's specs they get longer and thinner.
Here's the gist better than I can put it
http://wiki.answers.com/Q/Would_it_hurt_to_reuse_the_headbolts_on_a_95_2.0_ford_contour
2002 ford focme wagon
January 24, 2008, 04:24:35 pm
Baselyne
re-use head bolts?
January 24, 2008, 04:24:35 pm »
Right on, Thanks for that little link, That makes things seem very likly that stretch bolts are not to be re-used!
Has anyone had any experiences they'd like to share... In re-using h.bolts ? has anyone gotten away with it before?
What should a set of new IDI h.bolts be roughtly CAD?
January 24, 2008, 04:31:13 pm
re-use head bolts?
January 24, 2008, 04:31:13 pm »
Is it really worth reusing them? What's the cost of them not working in time and money compared to new bolts?
January 24, 2008, 04:33:37 pm
re-use head bolts?
January 24, 2008, 04:33:37 pm »
http://vwdiesel.net/phpBB/viewtopic.php?t=12336
same *** different pile :lol: don't re-use stretch bolts!!!
January 24, 2008, 04:51:00 pm
Baselyne
re-use head bolts?
January 24, 2008, 04:51:00 pm »
ok that's proof enough for me, Im sold on a new set that's forsure!
Were to buy in the Ont? Price roughtly?
January 24, 2008, 06:20:26 pm
re-use head bolts?
January 24, 2008, 06:20:26 pm »
The various WorldPac vendors sell them cheap cheap cheap, and OEM to boot:
click here
January 24, 2008, 11:12:39 pm
re-use head bolts?
January 24, 2008, 11:12:39 pm »
www.autopartsonlinecanada.com
is where I always get my stuff. I know it's cheaper sometimes other places but these guys have excellent shipping times (except when it comes from BC, which is rare unless it's a rare part) and they have good customer service in my experience.
January 25, 2008, 06:00:53 am
saurkraut
re-use head bolts?
January 25, 2008, 06:00:53 am »
What Motor?
If its a 1.5, you will probably strip a hole, or bust the block in one of the corner holes. The bolts are WAY TOO SHORT! I really believe its a design flaw.
Nos-hit, use any style head bolt in a 1.5 at your own peril. It will fail.
Buy either the ARP or Raceware stud kit. They both offer 11mm stud kits.
'79 1.6TD RABBIT
'84 1.5TD RABBIT
'83 Diesel Westy
92 Audi 100
'93 Eurovan
'82 Porsche 930
January 25, 2008, 09:06:15 am
Op-Ivy
re-use head bolts?
January 25, 2008, 09:06:15 am »
I wouldn't. It is definately worth the extra bucks to get them.
January 25, 2008, 01:40:53 pm
re-use head bolts?
January 25, 2008, 01:40:53 pm »
I reused my head bolts and haven't had any problems, yet.
Next time I'll get new ones of course.
Reply #11
January 25, 2008, 03:06:15 pm
Baselyne
re-use head bolts?
Reply #11 on:
January 25, 2008, 03:06:15 pm »
which engine was that in there rabbitman?
ive been wondering since im in there is there a list of other things that should be replaced> Ill be needing to get these things like pre-chambers and probubley timing belt and tensioner
what else you guys think?
Reply #12
January 25, 2008, 05:54:56 pm
re-use head bolts?
Reply #12 on:
January 25, 2008, 05:54:56 pm »
Prechambers don't get replaced, unless they are trash. Then you probably have bigger problems. Crank bolt, cap, rod, head bolts and heat shields are all I can think of that has to be replaced. Timing belt and tensioner should if you don't know the miles or it's getting close, but I wouldn't replace new ones for no reason. Head gasket gets replaced as should any seals you disturb. The oil pump doesn't hurt, but if it had good pressure, I personally wouldn't bother.
Reply #13
January 28, 2008, 06:17:44 am
saurkraut
re-use head bolts?
Reply #13 on:
January 28, 2008, 06:17:44 am »
FYI
Here's the Raceware 11mm studs installed in my 1.5TD. (hot valve clearence check photo)
The ARP studs probably look similar.
'79 1.6TD RABBIT
'84 1.5TD RABBIT
'83 Diesel Westy
92 Audi 100
'93 Eurovan
'82 Porsche 930
Reply #14
January 28, 2008, 06:27:49 am
Baselyne
re-use head bolts?
Reply #14 on:
January 28, 2008, 06:27:49 am »
So there studs then, It wont be a bolt like the one that I pulled out when removing the head?
Like fully threaded rod and a nut? or a regular bolt with a cap on the end....?
A freind of mine was using over sized drilled studs...
(They looked like the hub/lug studs that thread into the hub and put on nuts after) was this just a specific application as I think i heard him mention he drilled them and tapped them to hold a aftermarket stud kit!!!!!?
Im asking.... Do some companies make studs and some a bolt?
ARP's seem to be the best for a 1.6L re build? SOrry for all the questions, I thought at first they really were not too serious of a bolt but after reading everyones posts in this thread I do understand alot more about how much compression that new gasket is under...!
thanks everyone for your input and pictures
Props for taking the time to teach a newby
General Information
General
re-use head bolts?
