Author Topic: I need a little help..lol  (Read 4444 times)
January 21, 2008, 04:29:44 pm
KAC
  • 35
« on: January 21, 2008, 04:29:44 pm »
Ok here it goes..I put a 88  1.6 td in my Suzuki buggy...I did the governer mod....steel headgasket and non stretch bolts also intercooled it.I wanted to change it to serpintine belt ,,,,in my serch for a crank sprocket i got a 93 1.9td engine for free. But.....the top of the IP was  not on it .  other than that it is complete.  My Question is what can I/should I use off the 1.9 on the 1.6 to gain a little more hp/tq? The IP cam plate?IP head?
I already have a pyrometer before you ask...lol
Thanks!!!
Suzuki samurai with VW TD
Reply #1January 21, 2008, 04:41:11 pm
« Reply #1 on: January 21, 2008, 04:41:11 pm »
you could use the bottom end of the 1.9 and a 1.6 head...  that's a pretty good tq gain right there.  :wink:  plus it might be easier to get the serp setup working on that engine, just make sure to get the crank nose fixed if isn't already.
Reply #2January 21, 2008, 04:44:46 pm
« Reply #2 on: January 21, 2008, 04:44:46 pm »
You'd have kind of high compression though unless you took a bit off the pistons. Plus don't the 1.9 heads breathe better anyway which is why people put them on the 1.6?
Reply #3January 21, 2008, 05:28:46 pm
subsonic
  • 1836
« Reply #3 on: January 21, 2008, 05:28:46 pm »
Was this a 1.9NA converted to td?  What is missing from the IP, the LDA?
Reply #4January 21, 2008, 05:35:51 pm
KAC
  • 35
« Reply #4 on: January 21, 2008, 05:35:51 pm »
Quote from: "subsonic"
nope factory td...Thottle shaft all gone...she's wide open
Reply #5January 21, 2008, 05:54:43 pm
« Reply #5 on: January 21, 2008, 05:54:43 pm »
what about audi80 with 200+ hp using 1.6 head 1.9 block...
Reply #6January 21, 2008, 06:40:52 pm
« Reply #6 on: January 21, 2008, 06:40:52 pm »
Well the serp setup will bolt right on. If you feel like taking it apart again putting the 1.9 head on will net you the biggest gain, short of using the whole engine.
Is this for off road use only?
You might find the 1.9 turbo better suited (depending where you're RPMs normally sit) rather then the 1.6 turbo which is bigger
Reply #7January 21, 2008, 09:17:18 pm
« Reply #7 on: January 21, 2008, 09:17:18 pm »
Quote from: "jtanguay"
he has a 1.6 crank and 1.9na pistons, i dunno what rods are in it, i think he used a 1.6 head so he could get solid lifters.  but it ends up being a 1.7.  cool ass car
Reply #8January 22, 2008, 08:18:23 am
KAC
  • 35
« Reply #8 on: January 22, 2008, 08:18:23 am »
Quote from: "burn_your_money"
It's offroad only..
Reply #9January 22, 2008, 08:22:42 am
KAC
  • 35
« Reply #9 on: January 22, 2008, 08:22:42 am »
here's what I have to work with...open to suggestions:
K26 turbo
1.9 td (free engine.not running..not sure of condition...does turn overr though)
..I  was think of doing this
k 26 turbo
1.9 camplate
crank up the fuel...
so ...what's the good bad and ugly!
Thanks Kevin
Reply #10January 22, 2008, 08:53:05 am
« Reply #10 on: January 22, 2008, 08:53:05 am »
I'd probably try to find a smaller turbo. The k26 will take a while to spool up. A k14 would probably work well as it spools fairly quickly. Not positive, but I think t3's spool faster than a k26 also. I will eventually be helping a friend of mine with a tube frame Zuk rock buggy, and was thinking the fastest spooling turbo I could find would be, but I might get surge then. I did have a k-14 on my 1.9 when I first got it, and it did spool very well.
Reply #11January 22, 2008, 09:51:43 am
« Reply #11 on: January 22, 2008, 09:51:43 am »
Looks like Dr D. says a k03-003 would be a great choice, http://vwdiesel.net/phpBB/viewtopic.php?t=12298
Reply #12January 22, 2008, 01:51:24 pm
KAC
  • 35
« Reply #12 on: January 22, 2008, 01:51:24 pm »
I think the k14 turbo is ok,so...we'll say the turbo issue sorted out. Now what would you guys recommend? :D
Reply #13January 23, 2008, 06:16:36 pm
KAC
  • 35
« Reply #13 on: January 23, 2008, 06:16:36 pm »
Anybody?
Reply #14January 23, 2008, 06:22:35 pm
« Reply #14 on: January 23, 2008, 06:22:35 pm »
the current turbo on that thing should suffice right?
