Measure the gears... :wink:
Question, when is someone going to measure the outside of the 36 mm pump and compare it to the outside of a 30 mm pump?When at salvage yard quick and dirty is best! :twisted: Also, does the style of pick-up tube change with the year or with the size of the gears?tia
86->30mm pumps, 100% sure. VW started to use the 36mm units in late 87 early 88
