Author Topic: Oil pressure 1,9 TD AAZ engine  (Read 4016 times)
January 04, 2008, 06:24:40 pm
flajer
  • 9
« on: January 04, 2008, 06:24:40 pm »
Hi,
can anyone help me with numbers in Psi or Kg for oilpressure at idle, 2000, 3000 rpm, and max pressure in a warm AAZ?
Stefan
Reply #1January 04, 2008, 06:35:03 pm
« Reply #1 on: January 04, 2008, 06:35:03 pm »
Mine had 40 psi @ 2000 and 50-55 @ 4000 warm.
Reply #2January 04, 2008, 06:38:58 pm
« Reply #2 on: January 04, 2008, 06:38:58 pm »
The service manual gives one number:
- at the oil filter flange
- 2000 RPM
- engine at normal temp (fan has cycled once)
= minimum of 2 bar
Reply #3January 04, 2008, 06:59:28 pm
flajer
  • 9
« Reply #3 on: January 04, 2008, 06:59:28 pm »
sorry
Reply #4January 04, 2008, 07:01:20 pm
flajer
  • 9
« Reply #4 on: January 04, 2008, 07:01:20 pm »
Where are my problem? brand new engine head, turbo, oilpump, grinded crank, all bearings new, oversize pistons and rings 40000km.
Tested with 2 pressure meters on the engine head one electric and one mecanical.
23 psi @ 2000rpm and 40 psi @ 3000 rpm , cold@ idle almost 80 psi
oil 10w50
could it be the oil injectors for spraying the pistons?
Stefan
Reply #5January 04, 2008, 08:39:22 pm
« Reply #5 on: January 04, 2008, 08:39:22 pm »
new intermediate shaft bearings as well? Inaccurate gauge or sender maybe?
A torbo which needs and diesn"t have an oil restrictor?
Reply #6January 04, 2008, 09:33:55 pm
« Reply #6 on: January 04, 2008, 09:33:55 pm »
Quote from: "jimfoo"
10X  !!
IB4T Andrew   :wink:
(learned some new forum speak from my 12-year-old today !!)
Reply #7January 04, 2008, 11:44:48 pm
« Reply #7 on: January 04, 2008, 11:44:48 pm »
Quote from: "flajer"
The bentley numbers are for on the oil filter flange. You will have lower oil pressure at the head
Reply #8January 04, 2008, 11:57:14 pm
« Reply #8 on: January 04, 2008, 11:57:14 pm »
Quote from: "burn_your_money"
Yup... lots lower... the lifters bleed tons of pressure.  Your numbers look quite close to what I get when I measure at the head...
Reply #9January 05, 2008, 02:45:40 am
flajer
  • 9
« Reply #9 on: January 05, 2008, 02:45:40 am »
new intermediate shaft bearings and new bearings on the oilpump shaft as well.
IŽll try to messure on the oil filter flange today.
