Author Topic: IP on Ebay, will it fit  (Read 1992 times)
December 20, 2007, 04:01:45 am
DooeyTrials
  • 13
« on: December 20, 2007, 04:01:45 am »
Basically, will this pump from a 1991 1.6 td fit my 1990 1.6 td
I ask this because atm i have an eco pump and if i can get this one and it will fit i will then have an LDA
What do you think.
http://cgi.ebay.co.uk/vw-golf-passat-t25-1-6-turbo-diesel-injection-pump_W0QQitemZ320195146575QQihZ011QQcategoryZ9889QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Thanks
Chris
Reply #1December 20, 2007, 07:16:36 am
« Reply #1 on: December 20, 2007, 07:16:36 am »
looks like it should. I don't think there are any differences on 1.6 pumps that would keep it from fitting. If nothing else, you should be able to put the LDA on your pump.
Reply #2December 20, 2007, 09:11:37 am
« Reply #2 on: December 20, 2007, 09:11:37 am »
for some reason that pump looks like a 1.9 because of the 'strut' mounted to avoid a sticky control lever.
would be nice to see some pics of the shaft of the pump.. it looks like from the angle that it sticks out a little bit more than the 1.6 pumps.  i was going to use a 1.9 pump but scrapped that idea after i realized how much work it would have been to get the injection pump pulley re-welded to get it in line with the timing belt.
ask for a pic of the pump shaft just to be sure.
Reply #3December 20, 2007, 09:18:54 am
« Reply #3 on: December 20, 2007, 09:18:54 am »
I had kind of thought that too, but figured that maybe they put them on the 1.6 pumps as well. Either way, the LDA should still work on your pump I believe.
