IP on Ebay, will it fit
Topic: IP on Ebay, will it fit (Read 1984 times)
December 20, 2007, 04:01:45 am
DooeyTrials
Newbie
December 20, 2007, 04:01:45 am »
Basically, will this pump from a 1991 1.6 td fit my 1990 1.6 td
I ask this because atm i have an eco pump and if i can get this one and it will fit i will then have an LDA
What do you think.
http://cgi.ebay.co.uk/vw-golf-passat-t25-1-6-turbo-diesel-injection-pump_W0QQitemZ320195146575QQihZ011QQcategoryZ9889QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Thanks
Chris
December 20, 2007, 07:16:36 am
December 20, 2007, 07:16:36 am »
looks like it should. I don't think there are any differences on 1.6 pumps that would keep it from fitting. If nothing else, you should be able to put the LDA on your pump.
December 20, 2007, 09:11:37 am
December 20, 2007, 09:11:37 am »
for some reason that pump looks like a 1.9 because of the 'strut' mounted to avoid a sticky control lever.
would be nice to see some pics of the shaft of the pump.. it looks like from the angle that it sticks out a little bit more than the 1.6 pumps. i was going to use a 1.9 pump but scrapped that idea after i realized how much work it would have been to get the injection pump pulley re-welded to get it in line with the timing belt.
ask for a pic of the pump shaft just to be sure.
December 20, 2007, 09:18:54 am
December 20, 2007, 09:18:54 am »
I had kind of thought that too, but figured that maybe they put them on the 1.6 pumps as well. Either way, the LDA should still work on your pump I believe.
