General Information
Troubleshooting
10mm Tee So I Can Install Oil Pressure Gauge??? HELP
Topic: 10mm Tee So I Can Install Oil Pressure Gauge??? HELP (Read 5163 times)
December 19, 2007, 01:04:11 pm
mtnbob
December 19, 2007, 01:04:11 pm »
Ok, Bought a oil pressure gauge for my golf. Problem is the idiot light sensor is 10-mm. I was planning on getting a tee and running the pressure gauge off the same connection but I can't find 10-mm x 1.0 tees anywhere. Anyone else had this problem?? Any suggestions?? I don't want to gorilla the fitting into working. :shock:
96 Subaru Outback Wagon
December 19, 2007, 01:13:26 pm
December 19, 2007, 01:13:26 pm »
some cars have an extra port on the oil filter housing. i think its an allen type block that you unscrew and screw in whatever you need
you could try 3/8ths... i was going to do that once. it is just a little bit small, but you can compensate with some teflon tape or something..
10 millimeters = 0.393700787 inch
3/8ths of an inch = 0.375 inch
barely noticeable?
December 19, 2007, 01:17:06 pm
mtnbob
December 19, 2007, 01:17:06 pm »
Hmmmm let me check.........
I have another hole about 1 1/2 - 2" above the oil pressure light hole, but it doesn't look like a allen size nut i tried 7 mm too small 8 mm too big. Am I imagining things or is it
Square
inside the hole??
December 19, 2007, 01:53:35 pm
KTZed
December 19, 2007, 01:53:35 pm »
http://www.ttstuff.com/Merchant2/merchant.mv?Screen=PROD&Product_Code=VDO-240850
Get it from here or order from anywhere that sells VDO stuff with that part #
'85 2d Golf + 1.6TD - Winter daily driver on the build
'73 Datsun 240Z - Summer daily driver/autox racer
December 19, 2007, 02:56:19 pm
mtnbob
December 19, 2007, 02:56:19 pm »
Thank you very much. I ordered one and its on its way!!!!
December 19, 2007, 05:07:36 pm
December 19, 2007, 05:07:36 pm »
square ? hmmm i've never actually tried to remove the piece, but i will probably try someday
man i want to buy these tee's! nobody has them and im not paying $20 for shipping. but i might crack and suck it up
edit: hey
http://www.germansupply.com
finally has them back in stock :twisted:
December 19, 2007, 06:06:05 pm
mtnbob
December 19, 2007, 06:06:05 pm »
I got mine for 11 with shipping after searching the part #
December 19, 2007, 08:02:43 pm
December 19, 2007, 08:02:43 pm »
Quote from: "jtanguay"
Concept 1 in Calgary carries them for us Canadians... turbo tee reducers as well.
December 19, 2007, 10:28:12 pm
KTZed
December 19, 2007, 10:28:12 pm »
I just ditched the idiot light sensor...i decided it was for idiots :twisted:
December 20, 2007, 12:48:02 am
mtnbob
December 20, 2007, 12:48:02 am »
I considered it, but I would like the added alert of a buzzer and flashing light in my main cluster.
General Information
Troubleshooting
