Author Topic: 10mm Tee So I Can Install Oil Pressure Gauge??? HELP  (Read 5243 times)
December 19, 2007, 01:04:11 pm
mtnbob
  • 738
« on: December 19, 2007, 01:04:11 pm »
Ok, Bought a oil pressure gauge for my golf. Problem is the idiot light sensor is 10-mm. I was planning on getting a tee and running the pressure gauge off the same connection but I can't find 10-mm x 1.0 tees anywhere. Anyone else had this problem?? Any suggestions?? I don't want to gorilla the fitting into working.  :shock:
86 VW Golf 1.6 N/A 4-door (soon to be turboed!!!)
http://farm4.static.flickr.com/3248/2598033828_d3d19f9842.jpg?v=0
96 Subaru Outback Wagon
Reply #1December 19, 2007, 01:13:26 pm
« Reply #1 on: December 19, 2007, 01:13:26 pm »
some cars have an extra port on the oil filter housing.  i think its an allen type block that you unscrew and screw in whatever you need ;)
you could try 3/8ths... i was going to do that once.  it is just a little bit small, but you can compensate with some teflon tape or something..
10 millimeters = 0.393700787 inch
3/8ths of an inch = 0.375 inch
barely noticeable?
Reply #2December 19, 2007, 01:17:06 pm
mtnbob
  • 738
« Reply #2 on: December 19, 2007, 01:17:06 pm »
Hmmmm let me check......... 8)
I have another hole about 1 1/2 - 2" above the oil pressure light hole, but it doesn't look like a allen size nut i tried 7 mm too small  8 mm  too big. Am I imagining things or is it Square inside the hole??
Reply #3December 19, 2007, 01:53:35 pm
KTZed
  • 170
« Reply #3 on: December 19, 2007, 01:53:35 pm »
http://www.ttstuff.com/Merchant2/merchant.mv?Screen=PROD&Product_Code=VDO-240850
Get it from here or order from anywhere that sells VDO stuff with that part #  :D
'85 2d Golf + 1.6TD - Winter daily driver on the build
'73 Datsun 240Z - Summer daily driver/autox racer
Reply #4December 19, 2007, 02:56:19 pm
mtnbob
  • 738
« Reply #4 on: December 19, 2007, 02:56:19 pm »
Thank you very much. I ordered one and its on its way!!!!  :D
Reply #5December 19, 2007, 05:07:36 pm
« Reply #5 on: December 19, 2007, 05:07:36 pm »
square ? hmmm i've never actually tried to remove the piece, but i will probably try someday :)
man i want to buy these tee's!  nobody has them and im not paying $20 for shipping.  but i might crack and suck it up  :(
edit:  hey http://www.germansupply.com finally has them back in stock  :twisted:
Reply #6December 19, 2007, 06:06:05 pm
mtnbob
  • 738
« Reply #6 on: December 19, 2007, 06:06:05 pm »
I got mine for 11 with shipping after searching the part #
Reply #7December 19, 2007, 08:02:43 pm
  • 3255
    • My collection of HOWTOs
« Reply #7 on: December 19, 2007, 08:02:43 pm »
Quote from: "jtanguay"
Concept 1 in Calgary carries them for us Canadians...  turbo tee reducers as well.
Reply #8December 19, 2007, 10:28:12 pm
KTZed
  • 170
« Reply #8 on: December 19, 2007, 10:28:12 pm »
I just ditched the idiot light sensor...i decided it was for idiots  :twisted:
Reply #9December 20, 2007, 12:48:02 am
mtnbob
  • 738
« Reply #9 on: December 20, 2007, 12:48:02 am »
I considered it, but I would like the added alert of a buzzer and flashing light in my main cluster.
