Author Topic: IP won't budge  (Read 5337 times)
December 18, 2007, 10:45:26 pm
vegfuel
  • 125
IP won't budge
« on: December 18, 2007, 10:45:26 pm »
So I am in the middle of timing my rabbit 1.6na but I need to adjust the timing. I keep loosening more bolts holding the pump including the ones mentioned in the manual but the pump move  :( . I don't want to have to tap on anything which is usually the last resort. Is there some secret bolt that I forgot?
1986 Golf WVO converted.
Reply #1December 19, 2007, 12:19:48 am
Quantum TD
  • 1195
IP won't budge
« Reply #1 on: December 19, 2007, 12:19:48 am »
There are two bolts on the passenger side (one on the either side of the top). There is one NUT on the passenger side (lower center). In order to loosen it, the pump has to be at TDC so that you can slide a 13mm deep socket thru the cam sprocket and onto the nut. Then, there's one last bolt on the lower right corner (driver's side) of the pump. It bolts thru the cadmium-plated bracket that mounts to the distribution head.
If all 4 are loose, and the pump wont' move at all, then tap on it lightly with a rubber hammer.
Let us know how it goes.
Reply #2December 20, 2007, 02:00:38 am
Quantum TD
  • 1195
IP won't budge
« Reply #2 on: December 20, 2007, 02:00:38 am »
Any news on the little IP that couldn't?
Reply #3December 25, 2007, 10:54:39 am
Powjetta
  • 152
    San Diego CA
IP won't budge
« Reply #3 on: December 25, 2007, 10:54:39 am »
I had to loosen my fuel lines a little to help with the adjustment.
'86 jetta 2 dr Turbo diesel K24 - sold
'94 GMC 6.56TD - sold
Reply #4January 02, 2008, 05:15:58 pm
IP won't budge
« Reply #4 on: January 02, 2008, 05:15:58 pm »
It could be that the IP it a tooth off on the belt, yeah I know, you didn't wanna here that :wink:
Reply #5January 03, 2008, 07:27:11 am
IP won't budge
« Reply #5 on: January 03, 2008, 07:27:11 am »
