Author Topic: need part number of 11mm pump head/plunger and 1.9 camplate  (Read 13955 times)
December 18, 2007, 11:11:50 am
carrizog60
  • 978
« on: December 18, 2007, 11:11:50 am »
hello
can someone give the part numbers of this?
will the 11mm plunger work in stock head or do i need also a new head?
what would i need more?
thanks
Portugal
Reply #1December 19, 2007, 03:00:23 am
carrizog60
  • 978
« Reply #1 on: December 19, 2007, 03:00:23 am »
:arrow:
Portugal
Reply #2December 19, 2007, 06:23:03 am
« Reply #2 on: December 19, 2007, 06:23:03 am »
You need the whole assembly. You can't stick an 11mm plunger in a 9mm hole. As far as what you need, what are you trying to do?
Reply #3December 19, 2007, 08:13:19 am
carrizog60
  • 978
« Reply #3 on: December 19, 2007, 08:13:19 am »
mm well i got a stock 9mm pump and want to upgrade to a 11mm plunger and 1.9td camplate.
i want to do this because i want some more power and dont like to ride with the pump in the limit.
and thatīs  because the cold start lever almost doesent work and i need it sometimes in the morning as i have a 3 notch metal gasket(solid lifter head).
in cold it strugles and misses a bit when cold if the fuel screw is at is max...
i figure it would be better to have a bigger plunger and keep the fuel screw down so i can adjust the cold lever to act like stock does.
but i need the part numbers of what i need to be able to get the material... :arrow:
edit:what is the max rpm with the 11mm plunger?
i still want to do atleat 5000rpm...
Portugal
Reply #4December 19, 2007, 08:44:17 am
« Reply #4 on: December 19, 2007, 08:44:17 am »
I am far from a pump expert, but my understanding of the cold start is that it changes the timing at lower rpms, advancing it. I'd check your timing first before spending a bunch of time and money on stuff you probably don't need.
I'll let others chime in on the rest as I probably don't know enough to give advice it.
Reply #5December 19, 2007, 08:45:47 am
Benjamin
  • 485
« Reply #5 on: December 19, 2007, 08:45:47 am »
With IDI pressures there is no (efficient) limit with an 11mm plunger
i drived a 11mm plunger and never had any problems, i seen 6000 much times, just cause its cool. (i dont know how agressive my camplate is)
the head and the plunger always need to be toghether, you cant use a other plunger with the same head, even not if the part numbers do fit.
Why the camplate, you can get so much diesel with a 11mm...
anyway, if you do use another (higher lift) camplate you need to use the 2 (stronger) springs also.
Try to make it running with stock pump and just only a 11mm, you will see it can be hard enough  :wink:
Greetz, Benjamin
Must make +250hp
Reply #6December 19, 2007, 09:02:49 am
carrizog60
  • 978
« Reply #6 on: December 19, 2007, 09:02:49 am »
ok, so just the 11mm mod then.
so i need also the head of the pump and the plunger right?
nothing more?
can someone give me the part numbers for this then?
Portugal
Reply #7December 20, 2007, 01:42:23 am
carrizog60
  • 978
« Reply #7 on: December 20, 2007, 01:42:23 am »
but wont the tdi camplate  generate very high pressures?
Portugal
Reply #8December 20, 2007, 05:46:37 am
Tintin
  • 1279
« Reply #8 on: December 20, 2007, 05:46:37 am »
Quote from: "prothe"
You will need the TDI camplate to go with the 11mm rotor.  The 1.9TD camplate won't work with the 11mm TDI rotor.  If you have a 1.6 pump, you will need the springs and spring guides for the 11mm rotor/head assembly.
1: TDI came plate does not work with IDI pump.
2: 1.9TD AAZ 1995 and up have the proper came plate to adapt 11mm with bigger foot plunger.
3: I think that you have much reading to make in this forum about the pumps before answering anything.
Reply #9December 20, 2007, 07:26:07 am
carrizog60
  • 978
« Reply #9 on: December 20, 2007, 07:26:07 am »
so,i would need the 1.9td camplate.
wich one?
the problem is that the company that sells the parts need the part numbers,cant do anything witjout that...
so for the ones that have this mod:
any part numbers or even the name of what is needed and from what car/engine they come?
i would like to buy me this for cmas :lol:
Portugal
Reply #10December 21, 2007, 07:31:10 am
carrizog60
  • 978
« Reply #10 on: December 21, 2007, 07:31:10 am »
so can someone help me?
correct me if i am wrong:
i need a head and plunger of 11 out of a tdi(wich engine/year?) and a 1.9td camplate(1995 and up) right?
i dont want to deal with customs and shipping charges two times... :oops:
Portugal
Reply #11December 21, 2007, 10:42:30 am
« Reply #11 on: December 21, 2007, 10:42:30 am »
1.9 Cam plate out of a IDI AAZ pump
11mm pump head with plunger and you are set....
Reply #12December 21, 2007, 07:53:44 pm
oldskool rich
  • 446
« Reply #12 on: December 21, 2007, 07:53:44 pm »
dont buy one new, they will take your kidneys. i wudnt be suprised if you payed Ģ300
i went to my local breaker and found an 2005 AFN engine that had been dropped on the floor, they gave me the slightly damaged pump for free, i then just removed the 11mm pump and head, put it on my AAZ after a practice reseulting in snapping my origonal pump piston & 5 failed attempts lol, pumps are cheap from the scrapy and not the kind of thing that wares out. i should think any tdi after 2000 is a good bet will be 11mm+
ull need to run the AAZ camplate, trouble is that the pump is 0.58mm too big to fit the plate so will need to get a machineist to trim a bit off.
as for getting more rpm you need to do the governer mod if thats what you meen, which after youve done the pump will seem like a walk in the park
f6squared I.D.S.T
Reply #13December 22, 2007, 12:24:38 am
carrizog60
  • 978
« Reply #13 on: December 22, 2007, 12:24:38 am »
thanks rich.
i am going just to check for prices first.
is the difference is not that big i will buy new.
ou here(portugal) those pieces are rare in the scrap yards as the demand is big so the prices must be also high...
Portugal
Reply #14December 25, 2007, 01:30:56 pm
carrizog60
  • 978
« Reply #14 on: December 25, 2007, 01:30:56 pm »
well cant seem to get part numbers, can someone give me a pic or two with the exploded vision of the pump with the part surrounded so i can show to the shop?
Portugal
