Author Topic: Timing Gauge  (Read 20982 times)
Reply #15December 16, 2007, 08:09:13 pm
vegfuel
  • 125
Timing Gauge
« Reply #15 on: December 16, 2007, 08:09:13 pm »
Quote from: jimfoo
Looking at the crank pulley. Turn it with a socket and ratchet or breaker bar.
Turn the CRANK sprocket, not the cam. The pump has 3 bolts on the front and one underneath on the back. You should loosen the injector lines a little, but you don't need to remove them.
So if you are just turning the crank sprocket wouldn't you have to loosen the bolt that holds it on?
1986 Golf WVO converted.
Reply #16December 16, 2007, 09:09:20 pm
Quantum TD
  • 1195
Timing Gauge
« Reply #16 on: December 16, 2007, 09:09:20 pm »
Quote from: "chasingrabbitsvw"
Ok, so now I have the timing mark on the flywheel at TDC and the cams lined up in the right position. i screwed the gauge in and set it to 2.5 mm. I turned the engine counter clockwise. I keep turning and the gauge does not stop until the crank wont turn anymore. What am I doing wrong?
So since the valve timing was off do you think I'll find some bent valves when I pull the head?
What do you mean by the crank sprocket "won't turn anymore"? If the cam is timed properly with the bottom end, then you should be able to completely rotate the crankshaft in reverse (counterclockwise) rotation as much as you like, although its not advised to keep doing so. Did you leave the cam plate locked in????
I think some people made this WAAAY more complicated than it really needs to be.
First off: it your car was running before, then there was NO NEED to discuss cam lock plates, TDC, etc. If your cam timing was out, you'd know by the CLUNK of the valves being bent when you actuated the starter. This is probably too much for a novice to digest when all they need to do is set the pump timing. While it is a good idea to check the mechanical engine timing, it's not really needed to do this part of the job, especially when the car was running fine at one point not too long ago.
I understand that you had some problems with this car before, but I doubt that they had anything to do with the valvetrain or bottom end. They appeared after replacing a leaking injector line, so I doubt that the problem was related to engine mechanics.
ENGINE TIMING:
Now, since the cam lock plate has been dragged into the discussion, and we don't know how much of this advice has been taken to heart, you may as well take the time now to do this all properly.
1) Turn the engine to TDC (the notch on the flywheel that's visible thru the trans inspection hole is up, and both cam lobes for cyl # 1 pointing up or away from the cam followers).
2) See if you can install the Injection Pump lock pin. If you do not have the correct tool, a deep socket with outer dimensions just large enough to fit thru the hole on the cam will do (I find a 10mm works well). It should lock the Injection Pump sprocket to the Injection Pump mounting bracket/motor mount bracket.
Be advised, the pump can be locked at TWO different positions: one at TDC on the pump, and one at 180 degrees off. There should be a notch on the BACK side (driver's side) of the injection pump sprocket. When the pump is at TDC, the notch should be pointing straight up, and should roughly line up with the reference mark on the mounting bracket (groove), and the reference mark on the pump casting (the raised spline on the centerline of the pump on the sprocket side of the pump).
If you cannot lock the Injection Pump sprocket with the bottom end set at TDC, then the pump is off a tooth or two. If you can lock the IP sprocket, but CANNOT see the timing mark on the back of the pump sprocket, then the pump is out 180 degrees (assuming the other timing marks are on).
But if you've never played with the timing belt, and the car was running before, then this should not be an issue. If it is off a tooth or two, you will need to reset the timing belt according to Bentley manual.
3) NOW, check the cam. With the bottom end at TDC, and the injection pump locked in it's correct position, look at the driver's end of the camshaft. The locking groove should be completely horizontal: parallel with the top edge of the head. If you would like to confirm it, then slip a cam lock plate into the groove. If you do not have the correct tool, a straight file will suffice.
If the cam groove is NOT horizontal (i.e. you cannot lock the cam), THEN AND ONLY THEN, will you need to adjust the cam sprocket. When the timing belt stretches the cam timing might be off a touch, but not enough to cause engine damage. If it is drastically off the mark, then you will need to adjust the camshaft sprocket.
IF you need to adjust the cam sprocket, this is the procedure.
Lock the camshaft with the cam plate or similar tool. Loosen the 19 mm cam bolt a few turns (yes, you can use the cam tool to hold the cam while you loosen the end bolt, so long as some idiot has not over-torqued it beyond specs).
With the bolt loosened a few turns, tap the back-side of the cam sprocket with a rubber hammer (DO NOT USE A REGULAR HAMMER). The cam sprocket should spin freely. Now, tighten the cam sprocket bolt just enough so that the sprocket spins, but is not flopping around.
Go back and check your timing marks. The camshaft and injection pump should be locked at TDC, and the flywheel should be at TDC. If not, put them in their correct locations.
4) So, once all the timing marks are lined up (flywheel at TDC, Injection pump locked, cam locked with plate), you can now “Lock in” the timing setup.
IF YOU LOOSENED the timing belt tensioner during any of this, you will need to reset the tension.  So, with the flywheel at TDC, and the cam plate locked (cam sprocket loose enough to spin), REMOVE THE INJECTION PUMP LOCK PIN. Then, rotate the timing belt tensioner clockwise until you can twist the timing belt no more than 45 degrees at the point between the cam sprocket and the injection pump sprocket. Do not assume that tighter is better. I find that it’s best to give all of 45-50 degrees and then no more. Over tightening can cause intermediate shaft bearing failure, oil pressure loss, and then a blown motor (seen it happen).
Once the belt tension is set, confirm that the bottom end is still at TDC (should be no problems there). Then, tighten the CAM BOLT and remove the cam lock plate. At this point, you should go thru the following checklist:
1) cam sprocket bolt is tight, and properly torqued (45 nM).
2) timing belt tension is properly set (45-50 degrees of twist).
3) timing belt tensioner is torqued to proper specs (45 nM ).
4) Flywheel is at TDC
5) Injection pump at TDC
6) cam lock plate removed
7) injection pump lock pin removed.
If that is all done, then you can rotate the motor clockwise 2 turns by hand with some resistance (compression). If you feel really strong resistance, then you’ve done something wrong and need to recheck what you’ve done.
PUMP TIMING:
Ok. That's the engine timing. Now if all that checks out, you can turn to injection pump timing.
1) Make sure the cold-start knob (choke) is pushed all the way in on your dash.
2) Make sure that NONE OF THE LOCKING TOOLS ARE IN PLACE, and then rotate the flywheel to TDC.
3) Install the adapter (VW TOOL 2066) onto the dial indicator
4) Thread the adapter into the injection pump via the center hole on the driver's side of the injection pump (the 12 mm bolt hole), with the dial indicator inside of it, but DO NOT lock the dial indicator into the adapter.
5) With the adapter threaded completely into the injection pump, push the dial indicator into the adapter until the small dial (lower left dial graded 0-5)) reads at least "3".
6) Tighten the adapter onto the dial indicator so that it is locked in place with the small dial still reading at least 3 (3 mm of preload).
7) "Zero" the gauge by loosening the small knob on the indicator (top right at 2 O’clock). Then rotate the dial face so that the needle is pointing to zero. Lock the dial face by tightening the little knob on the top right of the dial indicator. (Some people may question zeroing the tool at this point, but it makes getting back to TDC alot easier if you miss the flat spot on the pump cam).
8:) Now, with NO engine parts locked (cam lock removed, IP lock removed), rotate the crankshaft counterclockwise with a hand tool (socket).
Rotate it SLOWLY. The needle on the dial should move counterclockwise.
The needle will rotate approximately 60-110% of a complete reverse revolution before it stops moving, despite the fact that you are still rotating the crank.
9) ONCE THE NEEDLE STOPS MOVING, you need to stop rotating the crank. If the needle stops moving, then starts up again, you will need to start all over. If you've rotated the crank a bit past the exact moment when the needle begins to stop, you're still ok to time the pump.
10) Once you've stopped rotating the crankshaft, and the needle has stopped moving, zero the dial indicator again (as you did in step 7 above).
11) Now, rotate the crankshaft pulley clockwise until the flywheel is at TDC.
The dial indicator should read about zero after making a complete revolution. This means that the timing is set to 1 mm according to Bentley. If it does not read 0, or you want to set the pump to a different setting, you will need to rotate the pump.
According to Bentley, your 1981 Jetta Diesel (assuming it has the original motor), should be set to .86 mm for standard setting, or .98 (1 mm) for improved performance (suggested if you have working AC).
12) If you want/need to adjust the pump timing as per Bentley specs/personal choice, then you will need to loosen the 4 bolts on the injection pump. There are 3 on the sprocket side of the pump and one on the lower right of the pump on the bottom.
To RETARD the timing (i.e. make the needle go counterclockwise), rotate the pump forward (away from the motor). To ADVANCE the timing, rotate the pump towards the engine. For minor adjustments, you should not need to loosen the injector lines. For large movement, you will need to loosen the injector lines.
13) Once you've achieved your desired timing setting, tighten all 4 bolts and double-check that the timing is still right. If it all checks out, then tighten the injector lines if you've loosened them.  Remove the adapter and dial indicator. Reinstall the 12 mm bolt to the injection pump.
14) Make sure (again) that all locking tools have been removed. Rotate the motor 2 full turns again by hand, just to be certain that nothing is binding.
15) Reinstall the timing cover and inspection plug (flywheel).
16) Start your motor and go.
For those who do not have a dial indicator, or for the brave of heart, you can adjust the timing while the motor is running: with or without the dial indicator. I've done it before, and it's easier to find the sweet spot where the pump works best (i.e. the engine runs smoothest).
In order to do this, you'll need to have the car at operating temps, otherwise you'll advance the pump timing too much. After the car is at operating temp,  you'll need to loosen all 4 IP bolts/nuts first, leaving one of them just snug (I usually leave the front one snug for easy access to loosen it at the correct moment). Then, start the motor with the choke lever pushed all the way in. Rotate the pump either way until you find (i.e hear) the optimum setting for idle/power/max RPM.
Be advised, if you've altered any of the original settings on your pump (i.e. max fuel screw, max RPM, idle, etc), you really shouldn't adjust your pump this way. The other settings will affect the engine's performance too much, and the timing can be way off, despite the fact that the car is running fine. Too much advance can do some damage in the long run.
Reply #17December 17, 2007, 08:48:22 am
addautomotive
Timing Gauge
« Reply #17 on: December 17, 2007, 08:48:22 am »
best post ever
Reply #18December 17, 2007, 08:08:30 pm
subsonic
  • 1836
Timing Gauge
« Reply #18 on: December 17, 2007, 08:08:30 pm »
May I suggest you copy and past directly to the FAQ section before this post gets buried and lost somewhere. Very good write up.
Reply #19December 18, 2007, 05:29:30 am
addautomotive
Timing Gauge
« Reply #19 on: December 18, 2007, 05:29:30 am »
+1.
I printed it. It's awesome
Reply #20December 20, 2007, 01:55:25 am
Quantum TD
  • 1195
Timing Gauge
« Reply #20 on: December 20, 2007, 01:55:25 am »
I could probably include some photos for a solid DIY. Not sure how that works, but I"m happy to do it
Reply #21December 20, 2007, 06:26:55 am
Timing Gauge
« Reply #21 on: December 20, 2007, 06:26:55 am »
Quote from: "Quantum TD"
i'll try to take pics of when i put my motor back together & time it.  but pics with instructions would be invaluable :)
Reply #22December 23, 2007, 09:38:49 am
chasingrabbitsvw
  • 37
Timing Gauge
« Reply #22 on: December 23, 2007, 09:38:49 am »
Great post. thanx for the help. it seems that both the valve timing and the pump timing are off. This is the way I received the car in September. I am replacing the head gasket and want to make sure I can time everything before I pull it apart, so that I can get the timing right after its back together again.
Reply #23January 26, 2008, 01:18:41 pm
chasingrabbitsvw
  • 37
Timing Gauge
« Reply #23 on: January 26, 2008, 01:18:41 pm »
Im up to step 8 on the directions below. Problem is, when I rotate counter clockwise, my gauge  stops after only 10% rotation. When I rotate back to TDC I get a reading of 4  mm. I have the injection pump fully retarded. Every thing is set to TDC; I have double checked. Why would my gauge stop so soon? what do I need to adjust?
8.  Now, with NO engine parts locked (cam lock removed, IP lock removed), rotate the crankshaft counterclockwise with a hand tool (socket).
Reply #24January 26, 2008, 02:02:37 pm
Timing Gauge
« Reply #24 on: January 26, 2008, 02:02:37 pm »
Try pushing the gauge a little further into the IP.
Reply #25January 26, 2008, 03:58:07 pm
Timing Gauge
« Reply #25 on: January 26, 2008, 03:58:07 pm »
Here's another take on setting the static timing using a dial indicator... still a work in progress but perhaps the pictures will help you ??
http://vincewaldon.com/index.php?option=com_content&task=view&id=24&Itemid=28
Comments welcomed... btw.
In terms of your specific issue...if you zeroed the gauge when it stopped moving as you rotated backwards (counterclockwise) AND you get a reading of 4mm after you rotated forwards (clockwise) to exactly TDC your pump is very much too ADVANCED.... sounds like you are aiming for a setting of 1.00mm... so you're 4X too advanced (assuming I'm interpreting your comments correctly ;-)  )
So, either the pump is pushed too far towards the head OR you're one or more teeth off on the injection pump sprocket.  4mm sounds like a lot more than a rotation issue so I'd be inclined to be really really sure the timing belt timing is perfect before carrying on with the IP timing.
Reply #26January 26, 2008, 05:07:33 pm
Quantum TD
  • 1195
Timing Gauge
« Reply #26 on: January 26, 2008, 05:07:33 pm »
Yep. You may not have enough preload. Did the small needle on the dial indicato read at least '2'? If not, then you'll have to push the dial indicator into the adapter a bit more as jimfoo noted.
You don't have to rotate the crank very much: about 2-5% of a complete revolution. As you rotate, watch the needle on the gauge. It should go at least about 40mm of rotation. If not (and there's at least 2 mm of preload), then your pump is WAY out of time.
Reply #27January 27, 2008, 08:58:36 am
chasingrabbitsvw
  • 37
Timing Gauge
« Reply #27 on: January 27, 2008, 08:58:36 am »
ok, got the pump timed right  now. The crank sprocket had jumped a tooth when we slid the timing belt on. I refitted it and re-timed everything, then tested for consistency. All appeared well.
Now:
When I try to turn the crank for a full revolution, it doesn't want to completely turn over at compression. I was really trying to apply some force too. It will not turn completely over. I even tried starting it at one point, but it would not. All tools are removed, the camshaft, flywheel and the pump are all at TDC.   One thing I was looking for, but could not find was where the pistons are supposed to be when the flywheel is at TDC.  I never played with the engine block or the flywheel, but maybe some thing was wrong there, I dont know.
Reply #28January 27, 2008, 10:31:11 am
Timing Gauge
« Reply #28 on: January 27, 2008, 10:31:11 am »
At the TDC mark on the flywheel pistons #1 and #4 are at the top of their travel (and #2 and #3 are at the bottom).
If it won't turn over by hand I'd advise against using the starter... that could bang things together much more forcefully.
If you are positive you found the correct TDC mark on the flywheel, AND you had the cam locked with both lobes of #1 pointed up, then the most likely possibility is that someone put your flywheel on wrong at some point.
The usual course of action in this case is to pull one of the injectors (#4 is probably the most convenient) and then using a long thin screwdriver or other metal implement as a marker confirm where TDC really is.  Because something is jamming you'll probably have to remove the timing belt and then loosen all the cam caps to so that the camshaft lifts and allows all the valves to close so that they don't bump into the pistons as you rotate the flywheel.
Loosening the cam needs to be done in sequence: cap 2 and 4 all the way, and then caps 1,3, and 5 slowly and a bit at a time so that the cam rises equally and doesn't twist and warp.
With the cam lifted you might want to do a rotation of the flywheel right off the bat... in case the obstruction *isn't* valves hitting the piston.
Reply #29January 27, 2008, 10:34:51 am
chasingrabbitsvw
  • 37
Timing Gauge
« Reply #29 on: January 27, 2008, 10:34:51 am »
I believe this is where the pistons were at TDC:
[/img]
