Author Topic: comparrison  (Read 3411 times)
December 05, 2007, 06:21:36 pm
shegel
  • 312
comparrison
« on: December 05, 2007, 06:21:36 pm »
what is an easy way to tell if a car has a 1.6 hydro head or a mech head...im considering the 1.6/1.9 franken motor.
1986 Golf 1.6l non turbo (R.I.P.)
1999.5 jetta (bought with 122145)
1969 karmann ghia(diesel swap dream)(most likely going to be subaru powered)
1998 jetta tdi (parents car)
Reply #1December 05, 2007, 07:52:29 pm
vanagonturbo
  • 639
    • Fine Tuning
comparrison
« Reply #1 on: December 05, 2007, 07:52:29 pm »
easy way is to notice an extra oil return galley between cylinder one and two. It is similar to the oil return between three and four but a little bit smaller.
I think you will need to look for a hydro block and not the head if you intend to build the 1.6/1.9 combo.
Reply #2December 05, 2007, 08:04:25 pm
shegel
  • 312
comparrison
« Reply #2 on: December 05, 2007, 08:04:25 pm »
Quote from: "vanagonturbo"
ok...but is that the easiest way to tell if i have a hydro engine or a mech engine.
Reply #3December 05, 2007, 08:34:38 pm
vanagonturbo
  • 639
    • Fine Tuning
comparrison
« Reply #3 on: December 05, 2007, 08:34:38 pm »
yes. Yours should be hydro if its original. I have seen scarier things though. I have a rabbit truck at the shop right now and it should have a 1.6l in it but alas, it has a 1.5l.
Reply #4December 05, 2007, 10:00:20 pm
comparrison
« Reply #4 on: December 05, 2007, 10:00:20 pm »
86 is the change over year, it could be either
Reply #5December 06, 2007, 09:22:58 am
shegel
  • 312
comparrison
« Reply #5 on: December 06, 2007, 09:22:58 am »
pre-?=mech
post-?=hydro
Reply #6December 06, 2007, 09:35:55 am
comparrison
« Reply #6 on: December 06, 2007, 09:35:55 am »
mechs are louder and have a little extra power.  there might be a sticker somewhere on the car that says you need to adjust the valves every 15'000km or however many miles.  if it doesn't have this it could have just worn off, but is probably hydro.
hydro pro's: no valve adjustment
hydro cons: sticky valve lifters
mech pro's: more power, no sticky valve lifters
mech cons: need to adjust valves on a regular basis.
i wonder if using really good oil could reduce the wear on the shims & cam... hmmm
Reply #7December 06, 2007, 09:42:13 am
shegel
  • 312
comparrison
« Reply #7 on: December 06, 2007, 09:42:13 am »
Quote from: "jtanguay"
im really hoping i have the hydro head....if i look on the car for when its made when did they go to the hydrolic head.
Reply #8December 06, 2007, 10:16:45 am
comparrison
« Reply #8 on: December 06, 2007, 10:16:45 am »
Quote from: "shegel"
pre-?=mech
post-?=hydro
pre-86=mech
post-86=hydro
VW makes it difficult once again
Read this thread and if you still have questions keep asking
