Author Topic: whats thread/size of turbo oil return connection on oil pan?  (Read 6195 times)
December 04, 2007, 06:54:43 am
flapjack
  • 283
« on: December 04, 2007, 06:54:43 am »
I'm replacing the stock oil return line on my 1.6TD. Does anyone know what thread / size the connection on the oil pan is?
signature
Reply #1December 04, 2007, 09:16:02 am
« Reply #1 on: December 04, 2007, 09:16:02 am »
I can get you the thread pitch tonight if I remember my tap and die set
Reply #2December 04, 2007, 05:23:47 pm
rabbid79
  • 684
« Reply #2 on: December 04, 2007, 05:23:47 pm »
It's Metric, and a very hard size to come by.  I took my pan to a major custom hose supplier, and they couldn't match it.  It was something like 23mm.  They had 22 and 24 in their catalogs, but no 23.  FYI, some pressure washers come with a brass fitting that uses the same size threads on one side.  It was just dumb luck that I discovered that.
'15 WRX
Reply #3December 05, 2007, 09:00:39 am
flapjack
  • 283
« Reply #3 on: December 05, 2007, 09:00:39 am »
thanks!
signature
Reply #4January 26, 2011, 08:42:26 am
BellCityDubber
  • 251
Re: whats thread/size of turbo oil return connection on oil pan?
« Reply #4 on: January 26, 2011, 08:42:26 am »
I'm bringing this one back from the dead
I looked in the "all encompassing oil drain thread"
http://www.vwdiesel.net/forum/index.php?topic=19623.75
some say it's a 23mm fitting
others say it's a DIN fitting available from gates
others mention a 7/8ths - 12? or 14? (or AN-10)
does anyone know what the oil pan return threads are?
Reply #5January 26, 2011, 01:14:05 pm
rallydiesel
  • 1880
« Reply #5 on: January 26, 2011, 01:14:05 pm »
Definitely not AN.
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #6January 26, 2011, 03:08:34 pm
BellCityDubber
  • 251
« Reply #6 on: January 26, 2011, 03:08:34 pm »
sorry that should have read
7/8 - 12 jic
or
10-an diameter hose (5/8ths)
seeing as JIC and AN are... for the most part, interchangeable.... the threads dont even look like they'll match up on the pan spigot... but the diameter is right....
Would it be a DIN fitting as quoted here
Quote from: myke_w
I finally got some info after hours of pouring over hydraulic fittings websites namely http://www.discounthydraulichose.com/
I've made a few discoveries.
All the hydraulic style fittings on German vehicles are of the type "DIN" which stands for Deutsche Industrial Norm .. This is roughly equivalent to the us SAE
FYI DIN has a 24 degree flare face
Another twist is that DIN fittings come in 2 grades - heavy and light.
These 2 grades are known by the industry as FDINLX (light) and FDINHX (heavy).
This grade impacts the thickness of the hole through the fitting, heavy being smaller ID because the fitting is beefier.
*You have to be sure that your hose size is the same between both ends  when making a hose up from scratch.
Gates carries these fitting so your local parts store can probably get them but they charge a ton compared to the aforementioned website (almost 25 bucks / fitting at my local parts house).
A typical gates part for an 18mm female DIN to crimped hose
# is G25645 - 12 18
« Last Edit: January 26, 2011, 03:13:58 pm by BellCityDubber »
Reply #7January 28, 2011, 05:39:04 am
BellCityDubber
  • 251
« Reply #7 on: January 28, 2011, 05:39:04 am »
I've got a buddy that works at a hydraulic shop giving me a hand.
from looking at this catalogue
http://www.geeve.com/documentatie/Crimp_Fittings_48.pdf
it looks like it may be part number 1CA48-15-10
when I measured the threads on the pan they came out to a m22x1.5 so I figure either I'm spot on or pretty damn close.
I'll be sure to post the results...
Reply #8February 18, 2011, 07:21:04 am
BellCityDubber
  • 251
« Reply #8 on: February 18, 2011, 07:21:04 am »
so I've got results.
I've been told it's a "15L metric"
I dont have a model number or size, but hose outer diameter I'm using is 15mm, the hex nut is 22mm
