Author Topic: Trying to rig a button for the glow plugs  (Read 3977 times)
November 22, 2007, 07:33:55 pm
flapjack
  • 283
« on: November 22, 2007, 07:33:55 pm »
I've searched
if there's a thread somewhere please point me to it!
I don't have the relay/control for the glow plugs. The motor is in a gas car.
Please tell me if this will work:
The fat wire going to the first glow plug gets connected to a fat switch and from the switch i run more fat wire to the battery
The head has to be grounded somewhere
When starting the car, i flip the switch on , count to twenty and flip it  off
and thats it?
thanks
signature
Reply #1November 22, 2007, 08:30:13 pm
« Reply #1 on: November 22, 2007, 08:30:13 pm »
It would, but I'd use a starter relay instead of a switch to control the current, then just run  small wires from the solenoid to a switch. That way you don't have a big unfused wire in the passenger compartment.
Reply #2November 22, 2007, 08:35:03 pm
gilligan5000
  • 63
« Reply #2 on: November 22, 2007, 08:35:03 pm »
Quote from: "jimfoo"
I have something like this, ford starter solenoid and a tiny momentary push button switch.  I count to about 7 though, not twenty
Reply #3November 22, 2007, 08:39:35 pm
« Reply #3 on: November 22, 2007, 08:39:35 pm »
that is your best bet.  keeps you safe from fire hazards.
Reply #4November 22, 2007, 08:43:58 pm
flapjack
  • 283
« Reply #4 on: November 22, 2007, 08:43:58 pm »
for the moment, the wire and switch will be under the hood  8)  along with the cold start (piece of string)
i'll worry about getting it into the cabin if i ever get the thing running
signature
Reply #5November 22, 2007, 09:09:51 pm
cowboybootlegger
  • 26
« Reply #5 on: November 22, 2007, 09:09:51 pm »
Here's a little poorly drawn picture to give you an idea...
I've used this setup successfully on older Ford diesels, using either a Ford glow plug relay (shown) or a Ford starter solenoid.  (same basic function, slightly different design)
Reply #6November 22, 2007, 10:29:55 pm
jackbombay
  • 599
« Reply #6 on: November 22, 2007, 10:29:55 pm »
Quote from: "gilligan5000"
  Cheap, and available everywhere.
Reply #7November 23, 2007, 12:21:59 am
lyeinyoureye
  • 96
« Reply #7 on: November 23, 2007, 12:21:59 am »
X643896547832y5wuithgfsc78943 on the ford starter relay. If ya want I can post piks/descriptions of my setup.
Reply #8November 23, 2007, 01:00:57 am
lyeinyoureye
  • 96
« Reply #8 on: November 23, 2007, 01:00:57 am »
I made that mistake a couple times and found my glow plugs still seem to work. Are some just more durable than others?
Reply #9November 23, 2007, 07:39:06 am
addautomotive
« Reply #9 on: November 23, 2007, 07:39:06 am »
I've been using the ford solenoid (as pictured above) in my Samurai.
Works like a charm
