Author Topic: changing ecu's?  (Read 4167 times)
November 05, 2007, 10:02:34 am
mk2tdi
  • 17
changing ecu's?
« on: November 05, 2007, 10:02:34 am »
i have the AHU engine which is 90bhp standard, ive ordered some .216 nozzles and was wondering if AFN ecu which is the 110bhp engine and fit it to mine would it help with power as i have read somewhere that the ecu's are the same its just it has a 110bhp map on the AFN. any help would be appreciated
5dr Syncro, AHU 1.9TDi, .216 Nozzles, Tuning Box, 3" Downpipe, FMIC, De-Cat, Just needs all putting together!
Reply #1November 05, 2007, 10:15:05 am
aidan
changing ecu's?
« Reply #1 on: November 05, 2007, 10:15:05 am »
No the AFN runs a different turbo, and the standard injectors on them are .205
If you decide to go VNT though that would be a good idea, but you'd need the turbo, downpipe, N75, vacuum reservoir.
You can get the chips you need off Aligator on tdiclub, no soldering needed on the AHU ecu. It'll do 140bhp on the standard turbo with minor smoke
Reply #2November 05, 2007, 10:25:47 am
mk2tdi
  • 17
changing ecu's?
« Reply #2 on: November 05, 2007, 10:25:47 am »
so if  istick with my AHU ecu and buy a chip from aligator i should be ok?
Reply #3November 05, 2007, 02:13:26 pm
MikkiJayne
  • 235
changing ecu's?
« Reply #3 on: November 05, 2007, 02:13:26 pm »
My AHU has surface mount chips  :(
If you can find an AFN ecu for a decent price I might be interested...
Reply #4November 05, 2007, 03:00:24 pm
mk2tdi
  • 17
changing ecu's?
« Reply #4 on: November 05, 2007, 03:00:24 pm »
Quote from: "MikkiJayne"
Hi, ill let you know if i do find one, what spec is your engine and in what car?
Reply #5November 05, 2007, 03:06:49 pm
MikkiJayne
  • 235
changing ecu's?
« Reply #5 on: November 05, 2007, 03:06:49 pm »
Standard AHU at the moment, but I'd like to fit a VNT eventually  :wink:
Its going in my Corrado starting tomorrow, since the 16V died today  :cry:
Reply #6November 05, 2007, 03:09:00 pm
mk2tdi
  • 17
changing ecu's?
« Reply #6 on: November 05, 2007, 03:09:00 pm »
cool, any other plans? tbh i dont know much about tuning them just starting out!
Reply #7November 05, 2007, 03:15:40 pm
MikkiJayne
  • 235
changing ecu's?
« Reply #7 on: November 05, 2007, 03:15:40 pm »
Well I'm ultimately aiming for 200bhp / 350lb ft. Nozzles, VNT18-22, FMIC, Rocketchip, Total Seal rings, ARP studs should do it 8)
A standard 1Z is going in the 'rado while I build a mad AHU in the background  :D
