VWDiesel Blog
Facebook Group
VWD on Twitter
General Information
Troubleshooting
Transmission differences?
Topic: Transmission differences? (Read 5046 times)
October 19, 2007, 09:10:51 am
flash319
October 19, 2007, 09:10:51 am »
I have a 98 Jetta and the reverse is just about gone out of it. (Idler gear or something). I have a 1.6 trans out of a 91. Will it bolt up without a problem? Use the same clutch as the 1.9 trans? Any help would be great.
Thanks
October 19, 2007, 11:57:39 am
g-spec
October 19, 2007, 11:57:39 am »
Is your a IDI....casue I dont think there were 98td....I think after 97 they all came TDI!!!
October 19, 2007, 12:22:56 pm
flash319
October 19, 2007, 12:22:56 pm »
ya its a IDI. 98 was the last year.
October 20, 2007, 09:55:59 am
Patrick
October 20, 2007, 09:55:59 am »
Could be IDI, they were selling both for a few years. I've seen a 97 with a TDI too.
October 20, 2007, 03:44:16 pm
October 20, 2007, 03:44:16 pm »
i thought '97 was the last year of the IDI.
October 20, 2007, 05:40:56 pm
andy2
October 20, 2007, 05:40:56 pm »
97 was the last year of IDI in the golf/jetta and also first year for tdi in the jetta.
October 21, 2007, 03:47:58 pm
flash319
October 21, 2007, 03:47:58 pm »
Well mine is a 98 IDI. Look up any parts and they list to 98 in Canada only. The US had the TDI in 97 I think in Jetta/golf.
ANYWAY.................its a IDI and will the 1.6L trans fit up to it? It is the one out of that 91 Jetta that you sold me Andy. I am going to do it in the next few weeks and want to order the stuff I need for it. Like a new clutch and a drive shaft.
Any info??
October 21, 2007, 04:10:15 pm
October 21, 2007, 04:10:15 pm »
i would imagine that you would need to swap over the flanges from your transmission to the 1.6 transmission (not too hard, but can be a PITA)
going from a '96 jetta TD tranny to a '92 1.6TD, the difference is sticking out about 1-2 inches from both sides while using the '96 flanges. the trans housing is the same, so swapping to some older 1.6 flanges made it work. now hopefully this tranny works good :?
October 21, 2007, 04:58:52 pm
andy2
October 21, 2007, 04:58:52 pm »
The older trans will bolt up fine and work provided that it is the 020 style trans with cable operated clutch.You'll have to swap the speed sensor and as long as the drive axle flanges are the same then you should be good to go
October 22, 2007, 10:06:28 am
flash319
October 22, 2007, 10:06:28 am »
So it looks like I may have to swap the axel flanges from the 1.9 trans to the 1.6. The 1.6 has the cable clutch. Do the flanges just unbolt?
October 22, 2007, 09:51:46 pm
andy2
October 22, 2007, 09:51:46 pm »
I havn't removed the flanges before.They could be the same size anyhow?Possibly someone alse could confirm?
Reply #11
November 07, 2007, 10:09:59 am
addautomotive
Reply #11 on:
November 07, 2007, 10:09:59 am »
I had the same issue, replaced the reverse idler and buttoned it back together:
I have a couple really good links here:
http://www.jakepalmeristheman.com/2005/08/august-30th-2005.html
Reply #12
November 07, 2007, 11:51:24 am
Reply #12 on:
November 07, 2007, 11:51:24 am »
Do you have a 020 or a 02A in your car right now?
Reply #13
November 07, 2007, 12:01:23 pm
Reply #13 on:
November 07, 2007, 12:01:23 pm »
Yup, I think you will find your current car has an 02A transmission, and your 1.6 donor is a 020. They are quite different from a swapping perspective... the 02A has a hydraulic clutch and cable shifters, the 020 is a cable clutch and linkage shifter.
This implies that your pedal cluster in the car will need to change, and the shifter housing, and....
No doubt it's been done... just a matter of how much time you want to spend.
Reply #14
November 08, 2007, 08:19:32 am
addautomotive
Reply #14 on:
November 08, 2007, 08:19:32 am »
However, you can use the 020 reverse idler in the 02a
General Information
Troubleshooting
