Author Topic: Turned in the fuel screw as much as humanly possible...  (Read 3251 times)
September 24, 2007, 08:29:20 pm
Black Smokin' Diesel
  • 656
« on: September 24, 2007, 08:29:20 pm »
...how in the world do I get the cold start lever to work again :lol: Fuel screw is in as much as my idle will allow (any more and I won't be able to get a decent idle speed). There's no adjustment left on the idle screw on top of the pump and next to none on the cold start adjust screws. Now I can't pull the cold start lever more than one inch and it does nothing. I adjusted the cable and played with both screws on the back of the pump but it didn't do squat.
I also played with the max RPM screw to raise it to 5600 instead of 5250 and adjusted the throttle cable. As a result , power cuts off at 4500 instead of 4000. After all these adjustements, I got quite a bit more power but there's something better: SMOKE!!! And a ***load of it. Funny thing is that the powerband changed quite a bit and most of the power is now found in the first half of pedal travel, the second half is just smoke with no significant added power. Before that all my power would be with the pedal to the floor with max power above 3000 cutting out at 4000. Now power builds up sooner at 2500 and cuts out at 4500.
What does this mean?
I've got massive amounts of smoke up top and smoke means potential power. All I need to do is hook up a boost gauge and a manual boost controller and take advantage of that.
Top speed however didn't change at all and is still a sucky 140kph. I think the main bottleneck is the transmission and drag. Hopefully the added boost will be able to overcome drag.
Mods to the engine:
-Mercedes 240TD injectors
-tweaked LDA
-upped fuel
-port matched intake and exhaust manifolds
-timing advance mod
-rebuilt K24
-1.9TD headgasket
Mods to come soon
-MBC
-boost gauge
-custom 2.5" or 3" downpipe (if budget allows)
Mods to come later
-ported 1.9TD head
-intercooler (already got a blackstone all aluminum unit)
-EGT, oil temp, oil pressure gauges
-water injection
-turbo timer
-governor mod
-other stuff I forget
Pics of the TD for good measure
Reply #1September 25, 2007, 12:47:20 am
vwmike
  • 1158
« Reply #1 on: September 25, 2007, 12:47:20 am »
While turning up the fuel screw helps, it just extends the injection period. That means at some point you will end up with fuel spraying too late and just making smoke instead of power. So, the next thing to do is improve fueling with larger nozzles or more importantly, a larger pump head.
Reply #2September 25, 2007, 06:40:24 am
myke_w
  • 1099
« Reply #2 on: September 25, 2007, 06:40:24 am »
I think your next mods should be EGT gauge and intercooler, or your going to melt something before you get a chance to mod it any further
Reply #3September 25, 2007, 07:37:53 am
Op-Ivy
  • 513
« Reply #3 on: September 25, 2007, 07:37:53 am »
Quote from: "vwmike"
Ahh I see. So that would be why, once turned in too far, the fuel screw will cause the engine revs to hang or keep revving up.
Reply #4September 25, 2007, 08:41:35 am
myke_w
  • 1099
« Reply #4 on: September 25, 2007, 08:41:35 am »
also, boost gauge so you know how close you are to popping your head gasket  :twisted:
Reply #5September 25, 2007, 09:20:16 am
rallydiesel
  • 1880
« Reply #5 on: September 25, 2007, 09:20:16 am »
Maybe your throttle arm needs to be rotated a bit so you can get the idle high enough and the fuel screw low enough.
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #6September 25, 2007, 09:41:38 am
  • 656
« Reply #6 on: September 25, 2007, 09:41:38 am »
Don't worry I don't make it smoke on purpose. As far as nozzles, the mercedes NA34X are plenty right now, I had the GTD before and they didn't do much better than stock.
My idle is good at 1000, that's as low as I can go. The engine doesn't rev by itself at all and doesn't hang RPMs either.
