Author Topic: Problems timing the pump  (Read 2732 times)
September 17, 2007, 12:47:22 pm
Maarten
  • 339
« on: September 17, 2007, 12:47:22 pm »
Since I rebuild my 1.9TD AAZ engine (and sat in a corner for ~1.5 years) I found a vanagon to put the engine in, the conversion was a lot of work but I completed it :)
but... I can't get the pumptiming to spec.
Flywheel set to TDC
Cam locked with plate and adjusted to center with shims.
Pump lockpin inserted
then I used this how-to (and some other, always come to the same result)
http://www.vwdieselparts.com/injtim.htm
Coldstart lever is pushed in
Flywheel at TDC lock pin inserted, gauge inserted at 3mm.
Turn back until the needle stops, pull out the gauge until small needle shows 1mm, big needle at 0
Turn forward till TDC.
Reading is somewhere between 1.80 (pump max away from head) and 2.40 (pump closest to head).
It idles ok but when running under load it produces load knocking so that must tell that the timing is off badly.
I think it pulls ok (in a 1500kg van, last car the engine was in was about half the weight)
I have done a governor mod with stiffer springs and some more fueling, nothing more.
Any ideas about this strange problem?
Audi A3 TDI '98
VW cabby '79
VW T3 1.9TD '91
Reply #1September 17, 2007, 01:13:56 pm
Maarten
  • 339
« Reply #1 on: September 17, 2007, 01:13:56 pm »
mmh.. seems that more how-to's on internet have the same error:
http://vwdiesel.net/phpBB/viewtopic.php?t=10269
there Vincent Waldon mentiones that there is an error, after turing forward to TDC it should be "reset gauge to 0 with both small and large needle at 0?
Audi A3 TDI '98
VW cabby '79
VW T3 1.9TD '91
Reply #2September 17, 2007, 08:55:23 pm
« Reply #2 on: September 17, 2007, 08:55:23 pm »
I just find it easiest to set the gauge to 0.000 once it stops moving as you turn the engine counterclockwise.... you then turn the engine clockwise to exactly TDC and read the timing value without any further math required.
Reply #3September 19, 2007, 02:02:47 am
Maarten
  • 339
« Reply #3 on: September 19, 2007, 02:02:47 am »
I just rechecked the timing, it was spot on 1.00mm (I set the pump where I tought it idled the best).
To find a solution for my dieselknock I set it to 0.90, knock still loud. Swapped the GTD single spring injectors for the original AAZ injectors, knock is still there...
any ideas to get rid of the loud knocking?
Audi A3 TDI '98
VW cabby '79
VW T3 1.9TD '91
