Author Topic: WTB AAZ valve cover and injector lines  (Read 4703 times)
September 07, 2007, 08:15:46 pm
subsonic
  • 1836
« on: September 07, 2007, 08:15:46 pm »
Looking for a AAZ valve cover and a set of 1.9TD injector lines.  Lines need to be in good shape please.
Thanks, Jim
Reply #1September 13, 2007, 01:29:51 pm
houseofdiesel
  • 210
« Reply #1 on: September 13, 2007, 01:29:51 pm »
What set of lines do you need? There are at least two different styles out there, I many sets and many valve covers $40 shipped for the lines $30 shipped for the v/c
Greg
Reply #2September 15, 2007, 07:22:57 pm
subsonic
  • 1836
« Reply #2 on: September 15, 2007, 07:22:57 pm »
Well, for the lines, I am not sure.
What I have is a 1.6 block and 1.6TD Giles pump.  Sitting on top is an AAZ head.  Not sure which style I need.  I guess I need 1.9TD lines.  Are these supposed to have a slightly larger interior diameter?  I need a AAZ valve cover as well.
Reply #3September 15, 2007, 09:55:14 pm
« Reply #3 on: September 15, 2007, 09:55:14 pm »
What injectors are you using?
Reply #4September 16, 2007, 06:55:30 am
subsonic
  • 1836
« Reply #4 on: September 16, 2007, 06:55:30 am »
Rebuilt 1.9TD injectors.  They are a bit taller than the 1.6.
Reply #5September 18, 2007, 05:25:19 am
houseofdiesel
  • 210
« Reply #5 on: September 18, 2007, 05:25:19 am »
This could be interesting...Let me look at the various lines I have and try to figure out which ones the least amount of height since your running 1.6 not 1.9 but taller injectors.
Greg
Reply #6September 18, 2007, 11:01:10 am
subsonic
  • 1836
« Reply #6 on: September 18, 2007, 11:01:10 am »
From what I understand, the block height is the same between the 1.6 and the 1.9.  I believe the heads are the same deal as well.  I think the only difference is the injector height.  I have the taller of the two kinds of 1.9 injectors.  The only other difference I can think of is that I am using a 1.6TD pump instead of a 1.9TD pump.  I know 1.6 N/A lines will not clear the LDA on a 1.6TD pump.  I do not know if the LDA on a 1.9TD pump would be any higher.  I guess it would not matter even if it was, if I use 1.9TD (AAZ) lines I would think I would be all set.
How do the lines look condition wise?
