Author Topic: Boost controller  (Read 7271 times)
September 02, 2007, 01:21:32 pm
MontanaGTD
  • 230
    • http://www.dub-style.com
Boost controller
« on: September 02, 2007, 01:21:32 pm »
I have a Garrett Turbo on my GTD - where do i fit the boost controller?
There is a solid metal pipe which runs front the side of the turbo (with a Banjo connector on the end I can see) and it runs around the back of the turbo and goes back into the back of the turbo - i've traced all the water / oil pipes and dont thing that that is one of them Am I right? Or can some one spread some light on this with a few pics??
MK3 Polo G40 - Sold
MK2 Golf GTD in Montana Green - FORSALE
MK2 Scirocco Scala 1.8i - FORSALE
MK4 Polo 6n 16v 5dr with A/C - othercar/wifes learner
Skoda Fabia VRS - new Daily
Reply #1September 02, 2007, 01:41:56 pm
MontanaGTD
  • 230
Boost controller
« Reply #1 on: September 02, 2007, 01:41:56 pm »
If you look on this ebay auction on the T3 rebuild kit there is a solid metal pipe (close to screw no12) which I'm hoping is the correct pipe to put my boost controller onto??
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&viewitem=&ru=http%3A%2F%2Fsearch.ebay.co.uk%3A80%2Fsearch%2Fsearch.dll%3Ffrom%3DR40%26_trksid%3Dm37%26satitle%3D220145133768%26fvi%3D1&item=220145133768
MK3 Polo G40 - Sold
Reply #2September 02, 2007, 04:29:43 pm
Boost controller
« Reply #2 on: September 02, 2007, 04:29:43 pm »
That sounds like where it should hook into. The metal pipe should go to the waste gate from the compressor scroll.
Reply #3September 03, 2007, 04:40:21 am
Choppercat
  • 42
Boost controller
« Reply #3 on: September 03, 2007, 04:40:21 am »
I just installed a boost controller a month ago on my 1.9. It came with a ''T'' with a restriction built into it. I installed it with the arrow pointing toward the waste-gate and the valve went into the modified ashtray for a stealth look. Then I went for a test drive and to my surprise, even with the valve fully closed the boost climbed to 15 psi. I never wanted to go past 15 so goodbye adjustability! I replaced the restricted Tee with a free flowing one and the boost dropped back to normal and I can now open the valve to adjust boost where I want it. Before installing it I did some research mainly on this forum and some recommended putting Tees and check-valves in the system but in my opinion check-valves are not required on a diesel as there is no vaccuum in the intake. Am I right or did I miss something?
DIESEL SMOKE IS ADDICTIVE!!!
'93 AAZ Golf
'99 Jeep TJ
Project: '51 Willy's CJ-3A AAZ
Reply #4September 03, 2007, 05:45:29 am
MontanaGTD
  • 230
Boost controller
« Reply #4 on: September 03, 2007, 05:45:29 am »
Mine doesnt have a check valve on it - its just the adjuster - I was sure it was the right pipe, even before I asked - but I wanted to make 100% sure before I go cutting it with the saw! Just need to fit my 3" straight through exhaust and i'm set!
MK3 Polo G40 - Sold
Reply #5September 03, 2007, 06:06:10 am
Choppercat
  • 42
Boost controller
« Reply #5 on: September 03, 2007, 06:06:10 am »
Coincidence! I took my exhaust out of the car yesterday and was planning a visit to the muffler shop this week for a 2.5'' straight pipe from the down pipe back. Let me know how it souds! I ran mine last night with no exhaust at all and it's loud! But I could have been listening to the turbo all night.
'93 AAZ Golf
'99 Jeep TJ
Reply #6September 03, 2007, 08:01:55 am
foxracer1
  • 991
Boost controller
« Reply #6 on: September 03, 2007, 08:01:55 am »
My buddy has a 2.5" straight pipe from turbo back on a 1.9 w/ K14 it sounds relativley quiet. And yes the turbo is sweet sounding.
91 S10 305 TPI T56
86 S10 2WD Prerunner project.
Reply #7September 03, 2007, 08:46:43 am
Demons UK
  • 21
Boost controller
« Reply #7 on: September 03, 2007, 08:46:43 am »
i've got a 2.5 straight through on my GTD.
Its louder then most exhausts, it sounds like a bad boy racer car mixed with a tractor tbh, the sounds pretty cool through and gets very queit after a few thou revs.
Reply #8September 03, 2007, 09:44:47 am
numbnuts
  • 99
Boost controller
« Reply #8 on: September 03, 2007, 09:44:47 am »
Quote from: "MontanaGTD"
If U are doing this, can u take some pics as i plan on doing this on mine? :lol:
Also what boost controller have u got and what exhaust?
Thanks alot, Joel
Reply #9September 03, 2007, 09:48:44 am
rallydiesel
  • 1880
Boost controller
« Reply #9 on: September 03, 2007, 09:48:44 am »
You probably already know this but don't forget to block off your intake relief valve (if the GTD even had this?).
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #10September 03, 2007, 09:57:05 am
MontanaGTD
  • 230
Boost controller
« Reply #10 on: September 03, 2007, 09:57:05 am »
This is the boost controller I fitted :-
The quote at the bottom of the listing from polo6n1600i is me!
http://cgi.ebay.co.uk/POWERTEK-BOOST-CONTROLLER-MK-2-GOLF-GTD_W0QQitemZ140153275484QQihZ004QQcategoryZ10428QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
I'm running a VAG downpipe (its off a GTD which didnt have any front silencer box) and I'll be fitting a complete Ashley Rally System. I'm a trader and got it at a huge discount direct from Ashley. Its a 3" straight through with 1 single can on the back and it end in twin 2.5" round pipes. I had one of their 2" systems on one of my old Golf GTi's and it was pretty loud. cant wait to hear what it sounds like on the GTD!
Oh and even with the controller just turned out 1/2 a turn i'm seeing just over 1 Bar of boost! Plus i've tweeked the fuel screw back 1/8 of a turn and it doesnt smoke like it use to. Cars in the rear view mirror use to dissappear!
MK3 Polo G40 - Sold
Reply #11September 03, 2007, 10:16:36 am
con
  • 106
Boost controller
« Reply #11 on: September 03, 2007, 10:16:36 am »
Hey montanaGTD if you get a chance could you snap me a pic of your freshly installed boost controller too?
Reply #12September 03, 2007, 10:18:39 am
MontanaGTD
  • 230
Boost controller
« Reply #12 on: September 03, 2007, 10:18:39 am »
Will do! I'm still messing with the pipework to get it up under the dash - Its currently in the service book slot and I can adjust it of i want, but it isnt easily to hand. So i'm thinking about getting some more pipe and remounting it through one of the switch blanks in the dash beside the speedo clocks.
MK3 Polo G40 - Sold
Reply #13September 03, 2007, 01:15:49 pm
MK2 GTD
  • 31
Boost controller
« Reply #13 on: September 03, 2007, 01:15:49 pm »
MontanaGTD
Wouldnt mind a few pictures of the boost controller install, also where did you T off for the pressure gauge.
Am in the process of fitting my radio into the bottom slot of a genuine Votex console, top slot for electric window switches.  Putting a set of VDO, Oil Pressure, OilTemperature and Boost gauges where the radio should be.
Hopefully get a few pictures of the install.
Reply #14September 04, 2007, 02:33:07 am
MontanaGTD
  • 230
Boost controller
« Reply #14 on: September 04, 2007, 02:33:07 am »
Same with me:-
 Gauges were the stereo normally fits, stereo in the lower vortex panel and electric windows switch in the upper vortex panel.
MK3 Polo G40 - Sold
