VWDiesel Blog
Facebook Group
VWD on Twitter
TDI Engine -General Info
Windage tray?
Topic: Windage tray? (Read 4824 times)
August 14, 2007, 05:54:09 pm
MikkiJayne
Windage tray?
August 14, 2007, 05:54:09 pm »
Hi everyone,
Has anyone tried one of these in a TDI? (AHU engine)
I'm wondering if the longer crank will have clearance problems, since this is designed for the 2.0?
Thanks, Mikki x
August 14, 2007, 06:04:10 pm
Audi80
Windage tray?
August 14, 2007, 06:04:10 pm »
Isnīt this stock in TDI :?: It is in 1,9 IDI
August 14, 2007, 06:17:53 pm
Windage tray?
August 14, 2007, 06:17:53 pm »
Quote from: "Audi80"
the TDI 1Z that i bought did not have one, although the oil pump had some sort of baffle on it.
August 14, 2007, 06:46:15 pm
MikkiJayne
Windage tray?
August 14, 2007, 06:46:15 pm »
Not in my AHU either. I know cos I took the crank out today to get the nose machined after pulley wobble :evil: Also discovered my big end and mains are toast too dammit!
I figure if it'll fit then it's worth putting in while it's in bits, since the original sump gasket was leaking anyway.
In the IDI's was it standard in the 1.6 or 1.9?
Mikki x
August 14, 2007, 09:52:31 pm
RabbitGTDguy
Windage tray?
August 14, 2007, 09:52:31 pm »
Windage tray was only stock in some 16v's from what I know and the ABA 2.0 engines.
I did install one in my AHU/1z build...its in the pics I believe as well. No issues. Fit very nicely. Biggest issue with the windage trays is that for many they don't seem to "seal" correctly. I haven't had that problem as of yet...
Now the valve cover (mainly upper grommets on p side/timing belt side...) thats another issue
Joe
1972 VW Westfalia
2001 Audi TT 225 Quattro Roadster (something newer
August 14, 2007, 09:57:20 pm
hillfolk'r
Windage tray?
August 14, 2007, 09:57:20 pm »
put it in,i got one
its just nice for the fact of the 1 piece rubber gasket that is reusable
ive had my pan off a few times since my rebuild,and its been worth it for the lack of scraping off nasty paper gaskets alone
itll help in the corners for sure,if not that the pickup isnt covered(thats another issue)
it helps keep the oil that is remaining in the pan from riding up its walls and hittin the crank
an old timer once showed me a trick
take a 1 qt oil can with a clear strip on the side,and pour out 1/2 the oil
reseal the lid
and lay it on your dashboard sideways so you can see the oil thru the clear section + tape it down+go 4 a ride
you will be surprised what is going on in your "oil pan"
a good trap door around the sump is great
im rambling
just put it in,i use just the ever slightest dab of sealer where the seal plates are meeting the block on the gasket surface
Throttle cables ftw
August 15, 2007, 02:50:13 am
Audi80
Windage tray?
August 15, 2007, 02:50:13 am »
Every AAZ I have seen had this from factory...
August 15, 2007, 05:17:43 am
MikkiJayne
Windage tray?
August 15, 2007, 05:17:43 am »
Thanks for the replies guys
Doing a bit more research the AAZ and 1Y seemed to have it from the factory but not the 1Z and AHU which is odd :?:
I'll definitely be fitting one now, when I get my crank back from the machine shop!
Mikki x
April 19, 2016, 11:24:51 pm
rotaecho
User+
Re: Windage tray?
April 19, 2016, 11:24:51 pm »
When installing the Windage tray on an AHU, did you use any type of sealant on each side of the baffle's rubber seal?
-Will
1982 Westfalia 1.6na diesel aka Betsy Bertha The Tortoise
Windage tray?
