Author Topic: More than timing issues!!!  (Read 3908 times)
August 06, 2007, 04:54:17 pm
g-spec
  • 289
« on: August 06, 2007, 04:54:17 pm »
someone on my golf messed with the pump and bracket and I cannot adjust the timing. the bracket is a newer style one (requiring a 2 piece pulley) and the pump sprocket is older style (one piece pulley). After looking for a 2 piece pulley I ordered one from the dealership, but it came without the hub (only sold with pump)....so I decided that I would make my own......now....I have already made it but the question I have is......how can I make it lock in place for doing timing belt jobs.....the pump does not have the hole for the 6mm lock.....should I use the keyway aswell??? I will take pics of everything.....
please help me out!!
cheers!
Michal
Reply #1August 07, 2007, 05:13:26 am
g-spec
  • 289
« Reply #1 on: August 07, 2007, 05:13:26 am »
the last one is of the hub I made....I havent drilled the tapered hole yet cause I want it to be the same as the original pulley. I was thinking about using a 6mm bolt to lock the pump with the new pulley....drilling a hole thru the hub into the bracket. let me know what you guys think!
Reply #2August 07, 2007, 06:13:10 am
« Reply #2 on: August 07, 2007, 06:13:10 am »
The stock setup for that pump uses a 6mm slot drilled in the hub which lines up with a holes in the bracket, you should be fine with that idea
Reply #3August 07, 2007, 07:27:51 pm
g-spec
  • 289
« Reply #3 on: August 07, 2007, 07:27:51 pm »
So I should just try and get the new pulley to lock as close as possible to the position the old one does???
Reply #4August 07, 2007, 08:27:30 pm
« Reply #4 on: August 07, 2007, 08:27:30 pm »
yeah as long as it is close you should be alright since the actual timing is done with the dial gauge, not the locking tool. As long as the belt will end up on the same tooth you'll be fine.
I'd try and use the keyway as a guide.
