#15
by
Audi80
on 29 Jul, 2007 05:35
Are you sure? Do you have aftermarket head?
1,9 HG will fit directly to engines with hydraulic lifters. You can easily make it fit to solid lifter engine too, just block the extra hole with piece of rubber.
There is original turbo engines with solid lifters from factory.
#16
by
cableroy
on 29 Jul, 2007 09:11
Hydraulic does not have visible springs right? they got this call "pusher" above/around the spring right? Thats what i have, and the guy at the shop came with a head gasket that was the same as my old gasket and he told me that this one was before 86 or something.
#17
by
on 29 Jul, 2007 12:42
i had a factory original 1.6TD mech engine in an 86. last year that they sold mech engines. I must say that car had some serious low end grunt. wasn't tuned for revving, but it could haul a car full of 'heavy set' people(5x200lbs or more) and still accelerate as if it was empty, but once 3k rpm hit, there was no balls, so next gear and away she went.
i still miss that car!!!
you can't use a hydraulic head on a mech block as far as i know.
#18
by
cableroy
on 29 Jul, 2007 13:33
i got a picture I'm gonna upload witch i took with the 1.9 TD gasket and the one i had, i'll try tomorrow.
#19
by
Black Smokin' Diesel
on 29 Jul, 2007 13:46
Look at this pic, see the big hump in the middle between the injectors #2 and #3? If you look to the left, there's another smaller hump between injector 1 and 2. Every hydraulic head has these two humps. If there's only one big hump in the middle, it's a mechanical head.
#20
by
Audi80
on 29 Jul, 2007 13:53
Mechanical AMC aftermarket heads have two humps. The smaller one is not drilled.
The lifter is above/around valve springs. Mech lifter has separate adjusting blocks between lifter and cam.
#21
by
cableroy
on 30 Jul, 2007 22:10
Yes looks like the one i got, but on the cam shaft bearings you have 3 bolts in the center, i don't have those...
#22
by
on 31 Jul, 2007 14:44
That's because it's a picture of a 1.9TD head. 1.6TD is pretty much the same except for those studs and intake/exhaust ports.
#23
by
cableroy
on 31 Jul, 2007 15:04
ok i see!
But hey listen up
i put my engine back, but apparently when i tried to start the engine the wheel on the camshaft have moved a little because of not tightening it enough, so now my valves has hit the pistons several times, but since the valves goes straight down to the pistons, any of you got experience if i can just time it again and run? Or do you think piston/valves are broken now, i'm not taking it apart to inspect, i'll rather just change the engine to a real 1.6 TD with diesel pump with "UFO"...
#24
by
Benjamin
on 01 Aug, 2007 06:50
is this a 1.6D or 1.6TD head?
mechanical or hydro?
thanks!
Greetz, Benjamin
#25
by
Audi80
on 01 Aug, 2007 09:08
1,6 hydro
#26
by
cableroy
on 01 Aug, 2007 09:41
#27
by
Audi80
on 01 Aug, 2007 12:38
You have mech block, head and lifters.
#28
by
on 01 Aug, 2007 13:16
Looks like your intake valves on 1 and 4 touched down for sure... did it warp the valve(s) ??
#29
by
cableroy
on 02 Aug, 2007 03:46
They look ok, and passed my leak test...
