Author Topic: is a diesel fusebox the same as a gas?  (Read 3115 times)
June 28, 2007, 01:34:58 pm
meatwagon
  • 10
« on: June 28, 2007, 01:34:58 pm »
i have a 97 IDI, was told i need a new fuse box, is it the same as a gasser or do i need to find a diesel fuse box?  thanks jamie!
97 jetta turbo diesel IDI
260,000 KMS
Reply #1June 28, 2007, 02:53:33 pm
Black Smokin' Diesel
  • 656
« Reply #1 on: June 28, 2007, 02:53:33 pm »
Pretty good question but I think you could make it work with a gasser fusebox.
91 Passat syncro 1.8T swapped.
Reply #2June 28, 2007, 07:17:51 pm
tylernt
  • 344
« Reply #2 on: June 28, 2007, 07:17:51 pm »
As far as I know the only difference in Mk1 and Mk2 fuse boxes is the place for the gasser fuel pump relay and the diesel glow plug relay.
I don't know if your '97 is considered a Mk2 because it's an IDI or a Mk3 because it's post-1992.
'82 Diesel Rabbit, '88 Fox RIP, '88 Jetta (work in progress)
Reply #3June 28, 2007, 10:52:21 pm
meatwagon
  • 10
« Reply #3 on: June 28, 2007, 10:52:21 pm »
oh , its an MK3, maybe ill just call vw
260,000 KMS
Reply #4June 29, 2007, 11:12:35 am
BlackTieTD
  • 1512
« Reply #4 on: June 29, 2007, 11:12:35 am »
ya ask the dealer for the part numbers for both. if they are different #s, try to find out what's different. if you can get a hold of ekta you can do this yourself.
Reply #5June 29, 2007, 09:38:57 pm
Kudagra
  • 738
    • www.no-coast.com
« Reply #5 on: June 29, 2007, 09:38:57 pm »
Quote from: "BlackTieTD"
Try the 1st link here...
http://vwdiesel.net/phpBB/viewtopic.php?p=65080#65080
Turbo boost libido and passive restraints
And as of yet I haven't heard even a single complaint
I've got the tools of the trade and a fuel injected heart
Efficiency is beautiful, efficiency is art
Reply #6July 01, 2007, 01:03:30 pm
Mk2Fanatic
  • 93
« Reply #6 on: July 01, 2007, 01:03:30 pm »
All CE2 Fuse panels are the same from late 88 til the end of mk3production in mid 1998 (as well as B3/B4 Passats).  I've swapped quite a few later fuse boxes into early CE2 cars gas/diesel doesn't matter.  Should be able to yank one out of a car in under 20minutes.  figure 25-75 from a wrecking yard.  just make sure when you pull it out of the car, the windshield was intact and not corroded arounded the molding.  Also check for corrosion on the relays and plugs when you remove it.  remove and replace take me about 45min...
5 VW's: Mojave beige (LE1N) Mk1 rabbit 16V; Mk2 Jetta wolfsburg TDI conversion;Mk2 1.6TD Twin Charged Project; 86Mk2 1.6TD Jetta (daily); 1988 1.6NA Jetta; 1994 Passat 1.9TD donor
Reply #7July 02, 2007, 12:04:54 am
meatwagon
  • 10
« Reply #7 on: July 02, 2007, 12:04:54 am »
thanks a lot for the help! much appriciated!
260,000 KMS
