I have a EQ 3 speed auto trans w/90mm Joint flanges. The target car is a 92 Jetta gas with 3 speed auto w/100mm axles and joint flanges. Can I use the 100mm flanges on the EQ trans?
If you swap flanges on the tranny you should be fine
Thanks Tyler, that's what I thought. I'll do the axle swap as well. Do it now before I drop the engine in...
