Hi,
Im about to replace my clutch disc, and Ive also seen that both flange seals are leaking, Ive arranged a clutch disc and pressure plate, but I dont have the flange seals.
If any of you people know that seal sizes, (theyre stamped on the seals themselves) please post them up, because as this golf is my daily driver, it would take me forever to find the seals as I have a tight working schedule.
If I knew the sizes I would just go and buy them from a seal specialty shop.
I'll try to remeber to check tonight
thanks - ill be waiting.
if you can eyeball the selector eyelet shaft seal also - it'll be great
This is what is stamped on my new set:
DGS 50 - 65 - 10 WDF01
It also says KACO 33 on the other side.
http://scirocco.org/gears/At the bottom of the page check your tranny code then the flange size.
Mine are the 90mm. I would assume most diesel ones are as well.
excellent
so its 10mm wide, 65mm outer collar, 50mm inner lip. (it should be directional also)
Great, thanks a million
op ivy -checked the box, its an ACH tranny 90 mm flanges.
Yes, there were arrows pointing both ways.
