Author Topic: Turbo oil flow restricter???  (Read 6773 times)
May 13, 2007, 03:28:30 pm
stewardc
« on: May 13, 2007, 03:28:30 pm »
I understand you need to restrict the flow of oil to a turbo (Why, I do not know)?? Where is this flow restrictor and how big is it?
PS: I have a Garett T3 on an AAZ.
Reply #1May 14, 2007, 09:50:11 pm
« Reply #1 on: May 14, 2007, 09:50:11 pm »
if there was no restriction, your turbo would leech all the oil pressure from the system.  another reason why oil drainage is crucial, since the turbo doesn't have full pressure.
Reply #2May 15, 2007, 03:19:03 am
stewardc
« Reply #2 on: May 15, 2007, 03:19:03 am »
But where is this restrictor and how big is the passage?
Reply #3May 16, 2007, 09:00:23 am
stewardc
« Reply #3 on: May 16, 2007, 09:00:23 am »
Anyone ???
Reply #4May 16, 2007, 07:00:20 pm
« Reply #4 on: May 16, 2007, 07:00:20 pm »
hmmm i dont know where it would be, but it's definitely not on the turbo judging from what i've seen on my T3 of course...
Reply #5May 17, 2007, 07:06:38 am
Justin
  • 455
« Reply #5 on: May 17, 2007, 07:06:38 am »
if your turbo doesnt have one then go to mcmaster car and you can order brass ones that are 1/8, 1/4 and I think 3/8" NPT to go inline with your oil supply line, look up hydrallic flow control i think that the largest they have is . 055 and .062, I just ordered some last night
www.archeryprostaffmi.com
Reply #6May 17, 2007, 07:19:25 am
« Reply #6 on: May 17, 2007, 07:19:25 am »
i'm considering using something like that for my bypass oil filtration system...  i don't want it to leech all my oil pressure, especially when driving nice and hard... which will be 50% of the time...  :twisted:
Reply #7May 17, 2007, 02:26:54 pm
andy2
« Reply #7 on: May 17, 2007, 02:26:54 pm »
The restriction your refering to is the oil supply fitting that connects the oil line to the turbo.The fittings ID is sized to allow a calculated oil flow through the turbo.I've compared fittings from a T3 to a ko3 and they have the same ID's.
Reply #8May 17, 2007, 04:44:24 pm
foxracer1
  • Authorized Vendor
  • 991
« Reply #8 on: May 17, 2007, 04:44:24 pm »
So whats the consensus? What size is good? I'm putting a VNT on my 1.6 and will be making an oil feed line from scratch. Also what size line? About 3 or 4 AN. With a 10 AN drain.
91 S10 305 TPI T56
86 S10 2WD Prerunner project.
Reply #9May 17, 2007, 04:55:29 pm
« Reply #9 on: May 17, 2007, 04:55:29 pm »
I think the small hole on your center section is the restrictor. I'd get a drain line at least the size of the larger hole.
