General Information
General
Turbo oil flow restricter???
Topic: Turbo oil flow restricter??? (Read 6918 times)
May 13, 2007, 03:28:30 pm
stewardc
May 13, 2007, 03:28:30 pm »
I understand you need to restrict the flow of oil to a turbo (Why, I do not know)?? Where is this flow restrictor and how big is it?
PS: I have a Garett T3 on an AAZ.
May 14, 2007, 09:50:11 pm
May 14, 2007, 09:50:11 pm »
if there was no restriction, your turbo would leech all the oil pressure from the system. another reason why oil drainage is crucial, since the turbo doesn't have full pressure.
May 15, 2007, 03:19:03 am
stewardc
May 15, 2007, 03:19:03 am »
But where is this restrictor and how big is the passage?
May 16, 2007, 09:00:23 am
stewardc
May 16, 2007, 09:00:23 am »
Anyone
May 16, 2007, 07:00:20 pm
May 16, 2007, 07:00:20 pm »
hmmm i dont know where it would be, but it's definitely not on the turbo judging from what i've seen on my T3 of course...
May 17, 2007, 07:06:38 am
Justin
May 17, 2007, 07:06:38 am »
if your turbo doesnt have one then go to mcmaster car and you can order brass ones that are 1/8, 1/4 and I think 3/8" NPT to go inline with your oil supply line, look up hydrallic flow control i think that the largest they have is . 055 and .062, I just ordered some last night
www.archeryprostaffmi.com
May 17, 2007, 07:19:25 am
May 17, 2007, 07:19:25 am »
i'm considering using something like that for my bypass oil filtration system... i don't want it to leech all my oil pressure, especially when driving nice and hard... which will be 50% of the time... :twisted:
May 17, 2007, 02:26:54 pm
andy2
May 17, 2007, 02:26:54 pm »
The restriction your refering to is the oil supply fitting that connects the oil line to the turbo.The fittings ID is sized to allow a calculated oil flow through the turbo.I've compared fittings from a T3 to a ko3 and they have the same ID's.
May 17, 2007, 04:44:24 pm
foxracer1
Authorized Vendor
May 17, 2007, 04:44:24 pm »
So whats the consensus? What size is good? I'm putting a VNT on my 1.6 and will be making an oil feed line from scratch. Also what size line? About 3 or 4 AN. With a 10 AN drain.
91 S10 305 TPI T56
86 S10 2WD Prerunner project.
May 17, 2007, 04:55:29 pm
May 17, 2007, 04:55:29 pm »
I think the small hole on your center section is the restrictor. I'd get a drain line at least the size of the larger hole.
General Information
General
