How do you adjust the Injector pump on a 1984 jetta diesel?
by
rabbit_diesel
on 12 Mar, 2007 19:42
Is there a special way to adjust the screw on the top of the injector pump without the engine running? How many turns are they required?
#1
by
on 12 Mar, 2007 20:56
the LDA fuel enrichment top? On some models that have it on top yea pretty sure you can do it. forget which way is more fuel though... maybe clockwise???
it is turbo right?
#2
by
rabbit_diesel
on 12 Mar, 2007 21:06
I know where the screw is, but I am wandering how far each way to adjust it. The motor doesn't run right now because I can't get the right amount of fuel to the injectors by guessing.
#3
by
on 12 Mar, 2007 23:05
well then you mean the screw pointing to the driver's side? it looks like a bolt that can be adjusted with a flat head screw driver. threading it counter clockwise (in) will increase fueling, while out will decrease fueling. I doubt that would be why the car isnt running though.
did you check the clear plastic lines to see if diesel is actually getting to the pump??? maybe its dry?? you have to remember that these pumps will not prime themselves.
#4
by
rabbit_diesel
on 13 Mar, 2007 06:09
It is getting fuel, I have a clear line in. Would the motor run no matter which way the screw is turned? Do diesels flood if they get to much fuel? thanks for the info :lol:
#5
by
on 13 Mar, 2007 09:49
yea it would be possible to flood a diesel... but you would need to be cranking a whole lot.. (injection pressures of around 1700 psi for N/A i think)
if the screw was turned all the way out, fuel should still reach the injectors, but not a whole lot. the engine would probably die at idle, but if you held your foot down it should run. if the screw was all the way in, it would start up, and probably run away and maybe overrev itself!!
if you crank and all you see is black smoke out the tailpipe, then its bad compression.
if you crank and dont hear the motor even attempting to fire, it could be bad/non functional glowplugs. i noticed that without the gp's the car would crank, but not even catch... (10C weather, worn out compression, but fired with GP's connected)
you can also check the fuel stop solenoid (red wire going to the injection pump) use a multimeter to check for power. while the key is on.
hope that helps
#6
by
on 13 Mar, 2007 12:26
#7
by
rabbit_diesel
on 13 Mar, 2007 17:40
Thanks for the info, jtanguay! I really needed that
. I will try pullstarting it when screwed out a little more than half and see what happens. I'll let you know.
#8
by
AdAm84
on 14 Mar, 2007 19:03
make sure you have fuel to the injectors. crack the lines at them while cranking. you should see fuel seeping around threads if you do. diesels need fuel and air. so check for both. thats why i dislike gassers that won't start. lol
#9
by
rabbit_diesel
on 14 Mar, 2007 19:32
Yes, the lines are bled. I just think it's cranking to slow, so that's why I'm gonna try pull starting it and getting the RPM's up. I didn't get around to it yet, but when I do... It will have no choice but to start
#10
by
on 14 Mar, 2007 22:27
if your ip timing is 180 out, it will start and run like utter crap.
#11
by
rabbit_diesel
on 15 Mar, 2007 13:42
How far off is 180? What should it be?
#12
by
rabbit_diesel
on 19 Mar, 2007 20:59
Well, I got to pull starting it today and it ran horrible :x! I ran it for a couple of minutes. Then all of the sudden I saw water viciously spraying out of the coolant cap worse than it was before I even replaced the head gasket. That's what got me mad. The head isn't warped either. It's time for me to rebuild the whole motor. What do you think the problem is with the coolant deal? Do those diesel headgaskets require a type of formula do to the very high compression ratio? I took the head off tonight and noticed that the head gasket was all black and the oval rubber seal was deformed. When I rebuild it this time what should I do differently? I'd appreciate any suggestions. thanks
#13
by
on 20 Mar, 2007 02:12
get your head pressure tested. The cracks in it may be entering the coolant passages
#14
by
rabbit_diesel
on 20 Mar, 2007 13:27
Well... By looking at the head, the only cracks I can see are the minor ones between the valves. It had to have been the head gasket because the rubber ring was even blown and deformed.
