Author Topic: VNT turbo  (Read 9908 times)
Reply #15March 17, 2007, 05:35:29 pm
OM617
VNT turbo
« Reply #15 on: March 17, 2007, 05:35:29 pm »
A GT37V used on the Ford Powerstroke and International DT466E's would do well for an engine that size.
Reply #16March 26, 2007, 06:23:41 pm
foxracer1
  • Authorized Vendor
  • 991
VNT turbo
« Reply #16 on: March 26, 2007, 06:23:41 pm »
:evil:  :x  :evil:  :x  :evil:  :x  :evil:  :x  :evil:  :x
D#$% F$%* S%$#
I bent my turbine shaft! I got to rammy and bent the shaft. So now i need a turbine/shaft, center section and a rebuild kit.
The compressor housing does infact say GT1749V. It says 49 on the inside of comp. outlet. So this means i have a vnt17 compressor, on a factory TDI vnt15 compressor? I guess i need a 15 turbine and a 17 or 15 center section.
91 S10 305 TPI T56
86 S10 2WD Prerunner project.
Reply #17October 26, 2009, 12:39:57 am
  • 2926
Re: VNT turbo
« Reply #17 on: October 26, 2009, 12:39:57 am »
Sooo... does anyone know a place to get one of these rebuilt,..
 or find a new one?
Reply #18October 26, 2009, 04:11:19 pm
foxracer1
  • Authorized Vendor
  • 991
Re: VNT turbo
« Reply #18 on: October 26, 2009, 04:11:19 pm »
I rebuild them!
91 S10 305 TPI T56
Reply #19October 27, 2009, 08:25:54 am
Re: VNT turbo
« Reply #19 on: October 27, 2009, 08:25:54 am »
where did you source your parts? i need bearings and wheels for my turbo. well, atleast bearings and seals. they are gone.
Reply #20October 27, 2009, 05:57:15 pm
foxracer1
  • Authorized Vendor
  • 991
Re: VNT turbo
« Reply #20 on: October 27, 2009, 05:57:15 pm »
i use G-pop shop they are real good guys. I'd recomend them to everyone.
91 S10 305 TPI T56
Reply #21October 28, 2009, 09:52:50 pm
  • 2926
Re: VNT turbo
« Reply #21 on: October 28, 2009, 09:52:50 pm »
I thought I had a spare center section to use while mine is getting rebuilt but it's different.
The other one is about 1/2" too narrow to even fit in the exhaust manifold.
 No holes where there are holes on the VNT-15.
 The vane operating levers are different.
 The compressor wheel is too wide for the bore.
 What kind of VNT is the one on the right?
Reply #22October 29, 2009, 08:05:39 pm
  • 2926
Re: VNT turbo
« Reply #22 on: October 29, 2009, 08:05:39 pm »
The other center section seems to be from a 2004 TDI BEW block.
 Called the KP-39
http://forums.vwvortex.com/zeropost?cmd=tshow&id=4615281
 Edit: Anyone know how these 2 turbos compare?
« Last Edit: October 29, 2009, 08:10:50 pm by fatmobile »
Reply #23October 29, 2009, 10:01:34 pm
OM617
Re: VNT turbo
« Reply #23 on: October 29, 2009, 10:01:34 pm »
Looks like a KKK turbo.
Reply #24October 30, 2009, 07:31:11 am
Re: VNT turbo
« Reply #24 on: October 30, 2009, 07:31:11 am »
looks KP 39 to me.
Reply #25October 30, 2009, 06:56:07 pm
  • 2926
Re: VNT turbo
« Reply #25 on: October 30, 2009, 06:56:07 pm »
How do they compare?
 Is one better at the low end but better up high?
 The KP-39 is a later model,..
 Improved in any way?
