TDI Engine -General Info
Need a Turbo!
Topic: Need a Turbo! (Read 4379 times)
February 23, 2007, 06:41:51 am
Need a Turbo!
February 23, 2007, 06:41:51 am »
Title says it all. I am getting a 1.6TD manifold donated to my cause. The goal here, is to have a good setup to get the car running, it will be mostly stock at this juncture, as I'd like to have it on the road by June. So, what are some good and CHEAP turbo options that will work for this purpose? Again, looking for good used turbos, not trying to win any races... yet.
Basically just something that will get the car rolling until next year when I tear it all apart and go hog wild. I guess the questions to ask are, what sort of turbos fit the 1.6td manifold and what size should I be looking for?
This is a 1.9 TDI, by the way. Not sure on the injection pump yet either.
Thanks!
84 Scirocco 8v <--- TDI in the works
01 Jeep TJ 4.0
'86 Golf N/A Diesel -->Wife's car
February 23, 2007, 07:45:50 am
SMOKEYDUB
Need a Turbo!
February 23, 2007, 07:45:50 am »
Hilfolk is using the sock 1.6 turbos right now the k24 i believe and he says he prefers the garret but either way hes running a 14 flat with them non intercooled and there cheap as hell.
12mm PUMP 'O' DEATH on a 1.6L
(courtesy of GILES)
2000 NISSAN XTERRA (5 SPD)
1984 RABBIT TD 2dr (SOLD)
1.8t AEB soon around 550 whp
February 27, 2007, 02:30:40 pm
Need a Turbo!
February 27, 2007, 02:30:40 pm »
the 14 flat was with the garrett, and to be fair, he does have water injection
February 28, 2007, 08:51:35 am
Need a Turbo!
February 28, 2007, 08:51:35 am »
Ok, check this out on Ebay:
Turbo
Would it work for a mechanical TDI, and would it bolt to a 1.6TD manifold? Price is right.
Thanks-
February 28, 2007, 03:49:35 pm
SMOKEYDUB
Need a Turbo!
February 28, 2007, 03:49:35 pm »
that wont bolt onto the factory manifold unless you make a spacer.
(courtesy of GILES)
March 01, 2007, 06:34:21 am
Need a Turbo!
March 01, 2007, 06:34:21 am »
So what I'm hearing is that only a factory 1.6TD turbo will bolt on to the 1.6TD manifold?
84 Scirocco 8v <-- TDI in progress
01 Jeep TJ 4.0
March 01, 2007, 09:07:28 am
RabbitGTDguy
Need a Turbo!
March 01, 2007, 09:07:28 am »
yes, only the factory VW diesel turbos will bolt to the factory manifold as it uses a unique trapazoid/keystone style flange compred to the standard t25 four bolt or a t3/t4 4 bolt flange. I've seen some pretty cleverly made adaptor plates though!
Joe
1972 VW Westfalia
2001 Audi TT 225 Quattro Roadster (something newer
Need a Turbo!
