#15
by
mst
on 28 Dec, 2006 07:25
Sorry to bother you since I probably will not be buying from you. I live in France, so the transport price will be expensive have seen on German eBay pistons for engine code
CS and JX (campmobile/bus), the price is right, 185 euro with sales tax, but my engine is a
SB; I do not know if they will fit, can you help me. I have written to the guy selling and he does not know!!
#16
by
myke_w
on 28 Dec, 2006 08:10
Is it a 1.6 or a 1.9? Is it turbo or NA?
#17
by
mst
on 28 Dec, 2006 08:47
The SB is a 1.6 turbo from a Passat from about 1989 (it is also used in the Golf Mk2.What I am afraid of is that the JX 1.6 TD do not use the oil jets, but if all vw 1.6 TD use oil jets then there should be no problem, but I cannot find engine code JX in Bentley nor in my other books
#18
by
myke_w
on 28 Dec, 2006 09:18
any 1.6 TD VW piston will fit, just be sure it has the oil squirter cutouts..
#19
by
mst
on 28 Dec, 2006 10:30
#20
by
myke_w
on 28 Dec, 2006 11:58
they look like the right ones to me..
#21
by
mst
on 28 Dec, 2006 13:17
Perfect,thanks for the help,happy new year
#22
by
moTthediesel
on 30 Dec, 2006 18:57
Myke:
Got the kolbens in mail today, they look great :!: :!:
Block off to M.S. next week to be dipped and punched out.
Hope to be making noise and smoke by spring --
moT
#23
by
myke_w
on 30 Dec, 2006 20:16
Excellent,
tip for you..
Tell the shop to leave the bores a bit on the loose side of the factory spec in the manual.. The motor will rev easier and won't feel tight..
#24
by
Fisher
on 01 Jan, 2007 02:04
What do you consider "a bit on the loose side" of the spec in the Manual?
Just wondering.
#25
by
myke_w
on 01 Jan, 2007 10:30
Section C # 4
Tight would be .02mm -- loose would be .05 .. If they'll cooperate, have them get closer to .05
#26
by
itzdshtz
on 01 Jan, 2007 11:08
Hi Myke, is it possible to supply 1 piston only in 77.01 mm?
I have a block that has one piston damaged, the rest is like new, only 5000 miles on a rebuild.
#27
by
myke_w
on 01 Jan, 2007 11:55
I can do one.. No problem.. paypal 82.50 to
[email protected] and I'll get it on the way..
#28
by
itzdshtz
on 01 Jan, 2007 12:36
Money send. Thanks, I will be back for more.
Herman
#29
by
Fisher
on 01 Jan, 2007 13:02
I know what the VW Spec is, I have the manual. There seems to be many conflicting opinions about this spec from different Shops. There are as many different opinions as there are different shops.
I'm just looking for information based on actual fact and experience.
Thanks for responding with your information.
