TDI, TD, GTD nozzles + Inj Pump seal kits ULSD+BioDsl ready
by
Smog
on 30 Nov, 2006 07:40
TDI, TD, GTD nozzles + Inj Pump seal kits ULSD+BioDsl ready (TD and TDI)
uprated 1.6GTD nozzles (RA/SB engines )
stock 1.9TD nozzles (AAZ engines)
0.205mm and 0.216mm nozzles for the TDI
IDI injection pump seal kit (1.6D 1.6TD and 1.9TD)
TDI injection pump seal kit (1996-2003 TDI)
IDI Pump shaft seal for pump sucking air
I can do COD for canadians (add 5$)
www.veg-injection-service.com
#1
by
LeeG
on 30 Nov, 2006 16:03
Do you still install and shim nozzles if someone sends injector bodies? How much for that?
How about the special socket for IP dissasembly?
#2
by
Smog
on 01 Dec, 2006 07:23
Sorry,
no more pop-testing on injector. You may ask your local BOSCH certified shop if they can do it for you
#3
by
on 05 Dec, 2006 16:34
nooo smog you dont pop test injectors anymore? i'm guessing something bad happened?
#4
by
Smog
on 06 Dec, 2006 07:28
Simply too much time consuming for a guy with 2 kids under 18 month old....
#5
by
DELETED
on 06 Dec, 2006 09:17
DELETED
#6
by
Smog
on 06 Dec, 2006 09:19
Do you have 1.6D seal kits in stock?
Yup, everything is in stock ready to ship
#7
by
commuter boy
on 06 Dec, 2006 19:08
Ah, wait a year or so, then you can get them to pump the handle for Papa.
#8
by
Smog
on 07 Dec, 2006 07:28
I may show them how to rebuilt my 1972 beetle; it will be better for customers
#9
by
commuter boy
on 14 Jan, 2007 14:01
Do you have seal kits for the 2.4 5 cyl AAB engines that were in the Canadian Transporters?
I'm curious as to how much of the 1.9 seal kits would match with them, the pumps look fairly similar on the outsides......
#10
by
Smog
on 15 Jan, 2007 07:05
the injection pump is similar but the kit I sell will be missing 1 small copper seal for the fifth delivery valve on your pump. I don't think it's a problem as they are rarely leaking but just to let you know. The rubber parts are all the same
#11
by
insdtanoodles
on 15 Feb, 2007 17:43
Is it just as easy as to take the old nozzels from my aaz and put new ones in or do the the new ones have to be shimmed and pop tested?
#12
by
Smog
on 16 Feb, 2007 07:06
the fabrication tolerances are tight, they can be reinstalled without pop-testing but if the car got over 250000km, it's a lot better to have the injectors reshimmed to the oem opening pressures.
they will work fine without shimming, you'll get the power, mpg and driveability gain but pop-testing them is the icing on the cake
#13
by
insdtanoodles
on 16 Feb, 2007 16:46
I guess I should get them shimmed then, cars got 247000km on original injectors
#14
by
red64chevelle
on 07 Jun, 2007 09:11
I just payed via PayPal for the injection pump seals, and GTD nozzels. I can't wait to finish my "GLD" project.
