aftermarket controller to control a VNT?
by
ezekiel
on 04 Sep, 2006 20:01
I haven't been thinking much about my motor lately, but I think my Rabbit is dieing, so I need to. Since I already have a TDI VNT, I'm going to use it on my AAZ.
Is there any reason that I can't use some sort of fuzzy logic controller, like a GReddy Profec and a strong vaccuum pump (possibly a second, dedicated one?) and let it control it like that?
Or, if that doesn't work, maybe take a microcontroller of some sort to make a solely RPM dependant boost control using an N75 valve?
#1
by
rabbid79
on 04 Sep, 2006 20:06
I am presently working on that very thing (custom controller) for my VNT Rabbit. IM me, and I'll fill you in on the specifics you'd like.
#2
by
OM617
on 04 Feb, 2007 06:57
Just replace the vacuum actuator with a boost actuator from a normal turbo.
#3
by
foxracer1
on 04 Feb, 2007 08:22
And that works safely? Some guys have brought up the possibility of a failure and the vnt sticking at max boost.
#4
by
Benjamin
on 04 Feb, 2007 08:26
you can rebuild the stock actuator, there is a hole, in the actuator, if you can make a pin on it, you can use this one. some guys did flipped the internals, some guys use an actuator from a wastegated turbo.
You can also use a external wastegate, but you dont NEED it.
more information can also found in the search
Greetz, Benjamin
#5
by
OM617
on 04 Feb, 2007 08:37
My turbo tops out around 13psi with the vanes wide open so no wastegate is needed. The actuator I use is from a Saab 9000 LPT and it maintains a steady 9psi of boost all the time. I'm currently working on a two step boost controller that will allow me to run 15psi at full throttle and 9psi the rest of the time.
LINKAnd that works safely? Some guys have brought up the possibility of a failure and the vnt sticking at max boost.
That's part of the risk when building custom setups. I've got the stock Mercedes overboost switch (16psi) wired to a $2 RadioShack 12v buzzer. It's loud enough to hear over the radio and engine in the event boost control fails.
#6
by
Tintin
on 04 Feb, 2007 08:40
Yes, it is not the best way to control a vnt , with large turbo it is less worse, but with this type of assembly will always have you max boost can imports how you run.
For an electronic control, that will take a sensor for indicated the position of the accelerator, the position of the RPM, boost sensor, and etc....
You can also make you a mechanical control, it is easy to make and that do not need precision to control the vanne, easy to adjust and cool to see :lol:
#7
by
foxracer1
on 04 Feb, 2007 09:44
So how much boost can these make max? Does it only make 13-15 max? sounds a little low.
#8
by
Slave2School
on 04 Feb, 2007 09:47
I depends on the model of VNT. The standard vnt-15 in my tdi was supposed to be OK to ~17.5psi the vnt-17VB version should be able to hold 22-23psi all day long and the "vnt-20" would be going beyond that.
#9
by
foxracer1
on 04 Feb, 2007 09:53
Well damn i was hoping to make more than that. But i guess it is much better down low.
#10
by
OM617
on 04 Feb, 2007 09:59
I know it's not a VW, but the Dodge sprinter I got my GT2256V from runs stock at 19psi and I currently run 15psi on my 3L MB diesel.
#11
by
Tintin
on 04 Feb, 2007 10:55
............ but with this type of assembly will always have you max boost can imports how you run.
I wants to say the max boost which you will have chosen and adjusted for your engine.
#12
by
OM617
on 04 Feb, 2007 11:00
Correct. My turbo always adjusts the vanes to maintain as much boost as possible up to it's maximum setting no matter the engine load or throttle application.
#13
by
Turbinepowered
on 04 Feb, 2007 11:01
Do dual VNT 15s. Biturbo 1.6 TD! :twisted:
#14
by
on 04 Feb, 2007 18:21
I'm currently working on a two step boost controller that will allow me to run 15psi at full throttle and 9psi the rest of the time. LINK
I sure hope they activate me soon so I can see what you are talking about...
