Hi ya'll been awhile. Some might remember my AAZ rebuild while broke down in Maine wow 14 years ago now.
Well I am ready to finally make the jump to a TDI. Now living in Southwest Montana the AAZ just isn't enough for me going up all the high passes so often.
I am debating on weather to go with an AHU or AFN TDI and have few questions mostly if I go AFN.
If going AFN will the VNT turbo work with the motor mount that I have? In the past it was commented on that I have the best mount for running bigger turbos. But I do not remember the exact details on what was said about it.
Here it is if someone could tell me if a VNT will work with this mount without any modifications or what makes it better then others?
Vanagon Diesel Mount by
RockOcean.com, on Flickr
If running a VNT turbo needs a custom mount or a bunch of other custom work could I just run my AAZ K03 Turbo on it? I know this will reduce it's performance but I am just wondering if it would work? If I wanted to go that easier route instead of doing a bunch of other custom work for right now. Later in the year I would do the custom work for sure. But I wanna drive across the country in two months so I don't have too much time to get this done.
I think that I want to go the ECU route since finding a reliable mTDI pump for under $1000 seems to be a hard thing to do?
If I do go ECU will an AHU ECU and wiring harness work on the AFN? And can it be tuned for whatever setup I end up going with?
I feel like just going AHU would be the easiest route since I could use my turbo and not worry about other custom work needing to be done. But I can't resist going AFN so I can get the better turbo, injectors, and pump for 22% more power to move my brick up mountain passes.
If I did go mTDI Pump what all is needed for that again? I have the bigger hole AAZ Pump Bracket which I think is needed? What else would I need? Do the AFN/AHU fuel lines work?
I think that's it - if there is anything else I need to look out for or any other recommendations for a AAZ Vanagon to TDI upgrade please let me know :~ )
