Injector overflow nipple removal
Topic: Injector overflow nipple removal (Read 5071 times)
January 08, 2023, 12:34:57 pm
33B
Bosnian with a money pit aka VW Passat 1987
January 08, 2023, 12:34:57 pm »
How do you remove the injector overflow nipple?
I bent one when replacing the injector heat shields and a crack formed making it leak.
1987 Passat B2 (33B)- 1.6TD JR, Audi 80 b4 front suspension and power steering. 280mm brake discs with 54mm calipers front. Rear MK3 disc setup with golf mk5 calipers.
January 08, 2023, 02:07:53 pm
Moderator
4549
Re: Injector overflow nipple removal
January 08, 2023, 02:07:53 pm »
Hmm, Never had to deal with that one. Can't see drilling them out and replacing them either.
time to get a new body for it. If you need one say something as I and most others likely have a stockpile of old injectors that we could send easily.
Just looked at your location info. Probably not something we in the states would be able to send quickly.
Last Edit: January 08, 2023, 02:09:39 pm by ORCoaster
January 08, 2023, 05:27:32 pm
January 08, 2023, 05:27:32 pm »
Since the one on the end usually gets plugged anyway.
You could probably just weld it shut and put it on cylinder 1 or 4.
January 09, 2023, 08:03:26 am
sgnimj96
January 09, 2023, 08:03:26 am »
http://www.peachparts.com/shopforum/diesel-discussion/308160-diesel-injector-return-nipple-leak.html
81 Scirocco 1.6D (conversion) 86 Gofl 1.6D 2003 Golf Tdi 1985 300TD
January 09, 2023, 10:31:25 am
33B
January 09, 2023, 10:31:25 am »
Thank you for your suggestions. Most likely i'll weld it shut.
January 09, 2023, 05:40:05 pm
Moderator
4549
January 09, 2023, 05:40:05 pm »
A Zap or two from the ole electric beast and your problem is solved. I like it.
January 11, 2023, 05:26:45 pm
sgnimj96
January 11, 2023, 05:26:45 pm »
good ol' JB Weld would probably work also. Spray it with brake cleaner and cover the whole thing.
Unfortunately, there would be some downtime waiting for it to fully cure.
