Mk1 Rabbit or Jetta Blower Motor for AC/heater Needed
by
tbro
on 04 Feb, 2021 10:24
I need a replacement for my 1982 Caddy heater/AC blower motor. The bushings are shot in my current motor and upon removal it seems to be non rebuildable. I am open to any suggestions on being able to replace bushings (if possible) from someone who has done this. Thanks for your comments, Tom
#1
by
on 04 Feb, 2021 19:32
They are readily available new for <$50.
#2
by
on 05 Feb, 2021 00:26
Hey Andrew,
Is that for the bearings or the MK1 AC heater fan?
#3
by
tbro
on 05 Feb, 2021 09:54
Thank you for the reply. Do you have a link or name of a place that cell the fan motor?
#4
by
on 05 Feb, 2021 10:53
I might have been mistaken. I got one recently for my rabbit, but it does not have A/C. If they are different for the vehicles equipped with A/C, then ignore my post.
#5
by
on 05 Feb, 2021 12:43
#6
by
tbro
on 06 Feb, 2021 02:03
Those look nothing like the one in my AC Rabbit pickup.
I would like to post a picture of the unit but can't seem to get it to work. Any ideas how to post a picture? I looked at help section but it did not work for me. Thanks
#7
by
on 06 Feb, 2021 11:54
#8
by
tbro
on 06 Feb, 2021 23:43
Thank you OR coaster it worked! Not mine but identical to the one in my AC caddy.
#9
by
on 07 Feb, 2021 01:37
#10
by
on 07 Feb, 2021 01:58
I've looked for the bushings but couldn't find any the right size.
Ended up making a few on my lathe.
They are 8mm hole and are round on the outside.
I don't remember what they are called.
#11
by
tbro
on 07 Feb, 2021 10:35
Thank you both for your comments. Making the bushings is no problem for me. Dismantling the armature case is the problem since the case is staked together and the squirrel plastic fan seems to be epoxied to the shaft. I tried pressing the shaft through the fan but stopped before I broke the plastic. If I can remove the fan I probably can deal with the case which houses the bushings.
The one in the picture Libby sent is different as I do not have the resistor. Thanks again for trying.
A real shame VW did everything to make the unit not rebuildable and then stopped making them available!
#12
by
tbro
on 07 Feb, 2021 10:45
Andrew, I sent an email to Samba seller to confirm status of bushings on his used motor.
Thanks again for looking for me
#13
by
on 07 Feb, 2021 19:57
Hmmm, the one in the picture you posted has the resistor.
#14
by
tbro
on 07 Feb, 2021 21:07
Yes you are right. The one in my truck uses an a circuit board that is mounted to the heater enclosure on one side. I do not know if it makes a difference.
