General Information
Upgrades (non engine related )
MK3 cluster into MK2 (TD)
Topic: MK3 cluster into MK2 (TD) (Read 5815 times)
August 10, 2006, 05:35:09 pm
X@V
August 10, 2006, 05:35:09 pm »
I have a MK3 wiring hardness with too much things on it (cruise control, A/C, alarm, etc.)
I need to know how the MK3 cluster could work on a MK2 wiring hardness. It's missing the VSS (3 wires). It's still not working!
What's missing?
August 15, 2006, 07:01:41 pm
August 15, 2006, 07:01:41 pm »
it should work
August 15, 2006, 07:03:55 pm
X@V
August 15, 2006, 07:03:55 pm »
A wire between E2 to D8 and it works. :wink:
I installed the MK3 coolong system on the MK2 wiring. It's simple!
July 03, 2007, 06:54:03 pm
X@V
July 03, 2007, 06:54:03 pm »
I have trouble
I have only 9V at the E2 to D8 junction.
When I turn the ignition switch on, the display disappear and the cluster doesn't work. The glow plugs indicator works but not the rest.
Do you have an idea?
July 03, 2007, 07:48:50 pm
July 03, 2007, 07:48:50 pm »
That's a common problem with the mk3 clusters. Try pulling up on the handbrake and seeing if the cluster works
July 08, 2007, 06:33:09 am
somolovitch3
July 08, 2007, 06:33:09 am »
If that works, means there is a lack of/poor grounding at the cluster, no?
Byte Me, Gently
81 Caddy (Trk)
84 Gti (DumBunny)
General Information
