Author Topic: Help! Crankshaft Pulley 85 Jetta diesel  (Read 6932 times)
February 06, 2020, 09:53:31 pm
robandjeanne
  • 6
« on: February 06, 2020, 09:53:31 pm »
Any ideas on where to get? May also need bottom timing belt pastic cover.
Reply #1February 07, 2020, 12:55:14 pm
Dennis Froelich
  • 256
Re: Help! Crankshaft Pulley 85 Jetta diesel
« Reply #1 on: February 07, 2020, 12:55:14 pm »
Timing pulley and possibly the bottom cover, try Parts Place.
I have purchased these items from them before.
79 Golf GTD
96 Golf GTD(TDI)
02 Golf TDI 2 door
Reply #2February 07, 2020, 09:20:29 pm
« Reply #2 on: February 07, 2020, 09:20:29 pm »
Anything on the floor here do you any good?
https://portland.craigslist.org/wsc/pts/d/north-plains-mk1-and-mk2-vw-rabbit/7065817821.html
Send a note, see what he says.  Maybe a shipper, Not sure.  Portland, OR
Reply #3February 07, 2020, 10:48:15 pm
robandjeanne
  • 6
« Reply #3 on: February 07, 2020, 10:48:15 pm »
Does anyone have the VW 9 digit number for the lower timing belt cover?
Reply #4February 08, 2020, 08:10:50 am
Dennis Froelich
  • 256
« Reply #4 on: February 08, 2020, 08:10:50 am »
068 109 127 B
79 Golf GTD
96 Golf GTD(TDI)
02 Golf TDI 2 door
Reply #5February 08, 2020, 08:18:31 am
robandjeanne
  • 6
« Reply #5 on: February 08, 2020, 08:18:31 am »
May have found the crank pulley if this one will work https://www.ebay.com/itm/vw-diesel-crankshaft-pulley-77-92-yr-068105255AH-068-105-255-AH/362868987472?hash=item547cad5650:g:JlAAAOSwG5teDVsp The part number is different though at 068-105-255AH. Also noticed a nice diagram of engine parts here https://www.vwpartsnetwork.com/v-1985-volkswagen-jetta--base--1-6l-l4-diesel/engine--engine-parts
Reply #6February 08, 2020, 08:29:32 am
Dennis Froelich
  • 256
« Reply #6 on: February 08, 2020, 08:29:32 am »
Are your parts missing or damaged or?
79 Golf GTD
96 Golf GTD(TDI)
02 Golf TDI 2 door
Reply #7February 08, 2020, 11:26:48 am
robandjeanne
  • 6
« Reply #7 on: February 08, 2020, 11:26:48 am »
Crank pulley is rusted through in spots bad enough to make it wobble. The lower timing belt cover under the crank pulley has been glued several times and the worry is it might fall apart gumming up timing belt and killing the interference engine.
Reply #8February 12, 2020, 02:34:03 pm
robandjeanne
  • 6
« Reply #8 on: February 12, 2020, 02:34:03 pm »
I found the crank pulley, but need to know if there is a difference between two VW part nos. VW says it is 068-105-255H, whereas I've found 068-105-255AH. In other words an extra letter "A" in the part no. Is this a big difference?
Reply #9February 13, 2020, 10:09:31 am
Dennis Froelich
  • 256
« Reply #9 on: February 13, 2020, 10:09:31 am »
I did some looking around and could not find a real difference in them. Anything is possible with VW though.
79 Golf GTD
96 Golf GTD(TDI)
02 Golf TDI 2 door
Reply #10March 02, 2020, 08:57:52 pm
  • 2922
« Reply #10 on: March 02, 2020, 08:57:52 pm »
I've heard bus depot sells the lower timing belt cover for the MK2,.. used for diesel busses.
