Model Specific Questions and Info
MK2 Golf/Jetta and Audi 5k
Help! Crankshaft Pulley 85 Jetta diesel
Topic: Help! Crankshaft Pulley 85 Jetta diesel (Read 7241 times)
February 06, 2020, 09:53:31 pm
robandjeanne
Newbie
February 06, 2020, 09:53:31 pm »
Any ideas on where to get? May also need bottom timing belt pastic cover.
February 07, 2020, 12:55:14 pm
Dennis Froelich
Re: Help! Crankshaft Pulley 85 Jetta diesel
February 07, 2020, 12:55:14 pm »
Timing pulley and possibly the bottom cover, try Parts Place.
I have purchased these items from them before.
79 Golf GTD
96 Golf GTD(TDI)
02 Golf TDI 2 door
February 07, 2020, 09:20:29 pm
Moderator
4552
February 07, 2020, 09:20:29 pm »
Anything on the floor here do you any good?
https://portland.craigslist.org/wsc/pts/d/north-plains-mk1-and-mk2-vw-rabbit/7065817821.html
Send a note, see what he says. Maybe a shipper, Not sure. Portland, OR
February 07, 2020, 10:48:15 pm
robandjeanne
Newbie
February 07, 2020, 10:48:15 pm »
Does anyone have the VW 9 digit number for the lower timing belt cover?
February 08, 2020, 08:10:50 am
Dennis Froelich
February 08, 2020, 08:10:50 am »
Quote from: robandjeanne on February 07, 2020, 10:48:15 pm
068 109 127 B
79 Golf GTD
96 Golf GTD(TDI)
02 Golf TDI 2 door
February 08, 2020, 08:18:31 am
robandjeanne
Newbie
February 08, 2020, 08:18:31 am »
May have found the crank pulley if this one will work
https://www.ebay.com/itm/vw-diesel-crankshaft-pulley-77-92-yr-068105255AH-068-105-255-AH/362868987472?hash=item547cad5650:g:JlAAAOSwG5teDVsp
The part number is different though at 068-105-255AH. Also noticed a nice diagram of engine parts here
https://www.vwpartsnetwork.com/v-1985-volkswagen-jetta--base--1-6l-l4-diesel/engine--engine-parts
February 08, 2020, 08:29:32 am
Dennis Froelich
February 08, 2020, 08:29:32 am »
Are your parts missing or damaged or?
79 Golf GTD
96 Golf GTD(TDI)
02 Golf TDI 2 door
February 08, 2020, 11:26:48 am
robandjeanne
Newbie
February 08, 2020, 11:26:48 am »
Crank pulley is rusted through in spots bad enough to make it wobble. The lower timing belt cover under the crank pulley has been glued several times and the worry is it might fall apart gumming up timing belt and killing the interference engine.
February 12, 2020, 02:34:03 pm
robandjeanne
Newbie
February 12, 2020, 02:34:03 pm »
I found the crank pulley, but need to know if there is a difference between two VW part nos. VW says it is 068-105-255H, whereas I've found 068-105-255AH. In other words an extra letter "A" in the part no. Is this a big difference?
February 13, 2020, 10:09:31 am
Dennis Froelich
February 13, 2020, 10:09:31 am »
I did some looking around and could not find a real difference in them. Anything is possible with VW though.
79 Golf GTD
96 Golf GTD(TDI)
02 Golf TDI 2 door
March 02, 2020, 08:57:52 pm
March 02, 2020, 08:57:52 pm »
I've heard bus depot sells the lower timing belt cover for the MK2,.. used for diesel busses.
