are a2 clusters plug and play?
by
SMOKEYDUB
on 16 Jul, 2006 13:49
i have a clock in my td and i have a cluster that has a tach in it and i noticed that there is a wire connected to the w terminal on the alternator. will the tach work if i plug it all in?
thanks
Jeff
#1
by
on 16 Jul, 2006 19:45
I know on the gas models there is a early and late mk2 cluster. I'm not sure about diesels, I'd have to check tomorrow. What years are they from?
#2
by
SMOKEYDUB
on 17 Jul, 2006 18:15
both have the double cinnector soits 89 i belive
#3
by
Dennis Froelich
on 22 Jul, 2006 04:13
Yes it will. As long as the wire is red with a black stripe. My(now) TD Coupe had a clock also. I had the cluster from my donor car that had the diesel tach. I swapped the cluster and plugged it in and it worked. :shock:
#4
by
bustedfoxwagen
on 23 Jul, 2006 13:46
i did the same and the tach won't go bast 3000 you know what might be happening?
#5
by
Dennis Froelich
on 23 Jul, 2006 16:51
Could be the tach itself. My tach works great, goes to redline and beyond.
Don't really know for sure what could be wrong. Sorry.
#6
by
bustedfoxwagen
on 23 Jul, 2006 18:16
that sucks! i just got it in yesterday and put it in today.... hope its not busted
#7
by
SMOKEYDUB
on 25 Jul, 2006 19:37
i did it and it works but only revvs to the gass gauge. :lol:
#8
by
madmatt
on 17 Aug, 2006 13:52
had problems with my t3 (vanagon)rev counter that was down to a bad connection in the engine the diesel clock seem to be more suseptable than the gas one,to test it i ran a wire from output w to the clock and it ran fine but by doing a resistance check on the origanal i traced it to a dry connection in the engine bay.
