Hello all! New to this forum but excited at all the expertise here and looking forward to reading up on all this stuff.
Anyhoo, I recently rebuilt a TD out of a Quantum and installed it in my Caddy. I replaced all the pertinent parts including trading turbo stuff with a friend wanting the Quantum stuff for his Dasher for Jetta stuff.
Once it was all together, it started fine but now all I have is a whinning restrictive exhaust. I suspected the wastegate since the blow off valve didn't even hav a chance to work. So, this is what I am wondering. While I have the turbo off, and as I read through other, it looks like the best thing to do to be able to have control over the boost is to delete it somehow. What is be best way to delete it? I am running the stock Garret turbo setup.
I will also be installing a boost gauge and EGT gauge (I have it, just need to install it) along with the oil press. gauge, oil temp gauge and volts gauge I already have (and keeping the oil idiot light) I believe I will be well informed of the engine performance.
LMK on the wastegate deal as I would really like to get this thing running soon!!
From what you describe, your machine is apart - hard to diagnose it that way.
I have an engine with low power - and just cut the steel hose going to the wastegate - and put a line and air guage to read boost pres.
I left the Blow of valve in place cause my head is dainty - needs gasket and bolts.
If your wastegate is broken - IE spring shot - change it now! - otherwise - it is a tune while running situation.
Cheers- C
