Irritating oil leak...
by
Patrick
on 08 Oct, 2018 14:46
AAZ in my Porsche, high mileage engine that always ran well. Oil at the front of the engine. Some on the turbo, and running down the block. Pulled the turbo and checked all connections on the drain line I modified to hook the T3 to the AAZ. Suspected the valve cover gasket so I changed that too. Did an oil change while I was at it and took the car out for a drive. Wet all down the front of the engine.
Camshaft seal maybe??? Not happy. Don't think I can change the seal without pulling the engine, not enough room.
Any suggestions for something I'm missing??
#1
by
on 08 Oct, 2018 19:35
In a case like that I would be spraying some engine degreaser on that engine and cleaning it up. Then letting the bugger idle for about 10 mins. Inspect with a bright light and an mirror if need be. Then IF nothing is showing itself to be dripping from the cover or seals, I would try revving it up some and see if the turbo seals are holding at boost.
Otherwise it will be a mess forever.
#2
by
Patrick
on 09 Oct, 2018 02:42
Engine is clean, oil is coming down the head on the right side at the timing cover...
#3
by
Patrick
on 09 Oct, 2018 16:26
Pulled the timing cover off after work, belt and pulley dry. Pulled the valve cover back off, gasket twisted right at the corner where it turns up to go over the cam. Put another gasket in, no more leak.
#4
by
on 09 Oct, 2018 19:52
If only all our troubles could be solved so simply. Glad you got it. I have an IP leak that is driving me crazy. Just going to put little bits of paper towel on it here and there and see which ones get wet and where.
#5
by
Patrick
on 10 Oct, 2018 17:36
Good luck with that! Only injection pump leak I've had was the seal on the input shaft. Happened to me twice on 2 different AAZ motors. Hard start problem that was the reason I bought the second one. Easy fix once I figured it out!
#6
by
GypsyR
on 18 May, 2019 18:13
I once had a daisy chain of leaks on my IP. Front seal then the big o-ring at the rear. Then down where the advance lever is. I got pretty sick of pulling and replacing the IP there for a while.
One neat way to find the exact source of a leak is to use talc. Degrease and wash and DRY the leak's general area. Then spread talc powder all over. I prefer to use "foot" spray in a can. Some folks just "poof" baby powder all over. Either way. Then do whatever makes it leak for a few minutes. The spray type sticks a LOT better if you need to get up the freeway speed to make it leak. Inspect. Whatever is leaking will have left a big obvious black trail through your pretty white powder. Leading you exactly to the source. Grab a water hose and simply rinse the powder away.
#7
by
on 18 May, 2019 19:19
Brilliant in the simplicity of it all.
And no more fungus or it smells like a baby for awhile.
