Opinions on aaz setup
Topic: Opinions on aaz setup (Read 3356 times)
May 12, 2017, 08:54:38 am
jpotsopt
Newbie
MK3 AAZ
May 12, 2017, 08:54:38 am »
hi guys,
i'm about to create an performance setup on a 1.9td aaz engine and i would like to hear your opinions
so this is the setup:
kkk24 turbo
10/11mm pump
intercooler from tdi90 1z
1.6gtd injectors
what do u thing of this? would it worth it? i'm open to sugestions
May 12, 2017, 09:16:19 am
Re: Opinions on aaz setup
May 12, 2017, 09:16:19 am »
Stick with the AAZ injectors. Nobody has seen any power gains messing with nozzles on the IDI engines. AAZ injectors are taller than 1.6 ones and use a more modern 2 stage injection setup.
What are your plans for the bottom end? We've seen a few failures of rod or main bolts on here over the years with built up AAZ engines.
The TDI intercooler is certainly better than nothing, but they aren't all that great. If you're choosing the K24 I expect you're looking for higher boost levels. The TDI intercoolers are known to pop apart if you feed them too much boost.
The K24 is a pretty dated turbo - they were introduced in the early 1980s meaning it's a '70s design. There's been a lot of progress in turbo design since then. A more modern turbo will spool faster, have more ultimate boost capacity and put less heat in to the discharge air. But if you have the K24 already it will certainly work with an AAZ.
May 12, 2017, 09:51:59 am
jpotsopt
Newbie
MK3 AAZ
May 12, 2017, 09:51:59 am »
my main idea is to look a "clear" engine, like the most oem possible. i want this build for a daily car so i'm not speeding up all the time just to give some life to the heart
so, dont change the injectors and choose another recent turbo. do u know if the 2056 from mercedes is hard to apply? i would like to keep that ic, does it take some pressure on that turbo?
thank you!
May 12, 2017, 02:24:13 pm
May 12, 2017, 02:24:13 pm »
It's really all about your goals and budget. If you want to keep that intercooler then keep your boost below 20 PSI and it'll probably stay together.
What vehicle is this going to be installed in? Turbo selection is a bit of of an art. Vehicle weight is a factor.
May 12, 2017, 05:35:41 pm
simonfredette
Newbie
May 12, 2017, 05:35:41 pm »
Following and dont mean to piggy back your thread but I am also rebuilding an AAZ, in my case to go into a mk1 cabby, it currently has the boost pin mod and a k14 doing roughly 20psi, the turbo compressor blades are looking rough though.. I am looking for a reliable car for long ish road trips and still have some power for pulls, would you get a new core for the K14 or what more recent turbo would you suggest?
May 13, 2017, 02:53:00 pm
Dubdoc
User+
[email protected]
May 13, 2017, 02:53:00 pm »
I did the same setup almost 7 years ago for my 1981 Caddy. I used a Garrett T3 (like a K24) running about 20psi, a Giles pump (Performance Diesel Injection) with AAZ injectors. I used ARP bolts/studs throughout and ported the head. I used a 3" custom downpipe and a 2.25" exhaust with a Magnaflow muffler. I didn't use a intercooler till it was broken in, then used a Saab Blackstone cooler (similar to the TDI cooler. Be sure to use a HEALTHY clutch as these motors are torquemonsters. I couldn't be happier with the setup.
May 15, 2017, 04:34:32 am
May 15, 2017, 04:34:32 am »
sounds like about 150hp
May 15, 2017, 10:06:58 am
Dubdoc
User+
[email protected]
May 15, 2017, 10:06:58 am »
150 Horses and 255 ft lbs. All you'll ever need !
