Doing a AAZ into 1981 Caddy , looking for a pair of MK2 spindle so the axles will work ? thanks
I'm guessing you are using the AAZ transmission?
I think most people either swap the axle flanges on the transmission or swap the inner CV joints. You can buy mk1 100mm axles as well.
You will need scirocco 16v spindles or 87+ cabriolet ones
burn money thanks , I did not know that ,
There is a way to put the later MK2 spindles, with the bigger bearing and ball joint into a MK1.
You'd have to do some research on the vortex.
