Dyno'd the Caddy, need help fine tuning
by
chiefdiesel
on 01 Jun, 2014 20:07
The Caddy was on the rollers a few weeks ago and posted a high of 203.1 hp of 3 runs. The shop (Allspeed of Peachtree City Ga) didn't have an adapter to read the revs for a chart of the torque. Here are the details according to my Auto Meter gauges: 203.1 hp @ 4000rpm (custom fuel cutoff), boost reached 45 psi, and egt approx. 2000 degrees. The block is stock AFN, 1Z head (8K miles), Garrett GT 2056 wastegated turbo (rebuilt with upgraded journal and thrust bearing), R520 w/custom pressure injectors, LT 12mm ip (Giles super pump mod set to 80% flow), fmic and 2" dp and straight pipe. Should I add w/m setup or custom intake and exhaust manifolds, and larger intercooler?
#1
by
chiefdiesel
on 01 Jun, 2014 20:45
Also, what about a ALH head....supposedly better flow than a ported 1Z/AHU head?
#2
by
GEE-BEE
on 01 Jun, 2014 21:06
Didnt know it would fit the ahu ?
How do you like the M-TDI 12 mm pump
I ordered a new one as I did want to round up cores for Giles to build
#3
by
chiefdiesel
on 01 Jun, 2014 21:12
AWESOME! Especially after Giles worked his "majic"! Im desperately trying to post a few vids of the runs. This pump is capable of supplying huge amounts of fuel. A few mods need to be done for the head to fit.
#4
by
chiefdiesel
on 01 Jun, 2014 21:30
#5
by
GEE-BEE
on 01 Jun, 2014 21:40
Better results with less alloy tubing getting heat soaked
dual fan also, larger radiator
What wheels are those, I trimmed 1.75 off each side of my rear axle for no more rubbing problems when lowered..
GB
let me know if I can make you anything custom
Here is my list of aircraft stuff
http://www.csobeech.com/GeeBee.html
#6
by
Rising
on 01 Jun, 2014 23:10
2000° EGT?
Great numbers! I just didn't know aluminum could deal with that!
Sent from my Nexus 5 using Tapatalk
#7
by
on 02 Jun, 2014 05:00
#8
by
on 02 Jun, 2014 05:39
with that much EGT I would invest in a Holset. You could run 1/2 the boost and have lower EGT. Good numbers. The other thing I would do to lower the EGT is go to 2.5" exhaust all the way. Water meth would help, but to get this to live I think you need some better hard parts. Then you could see what is needed or if you want to go custom on the exhaust and intake. The only numbers I could get for this turbo was like 16lbs/min and this from another site :
http://306oc.co.uk/forum/archive/index.php?thread-11198.htmlGarrett GT2056S CHRA number 714652 (ext 5005, 5006)
Model: 751578-2
CHRA: 433289-234
Bearing: Journal
Cooling: Oil
Compressor
Inducer: 41.5 mm
Exducer: 56.0 mm
Trim: 55
A/R 0.53
Turbine
Wheel: 47.0 mm
Trim: 72
A/R: 0.46
Wastegated
Realistically on a 9mm pumped 1.9 XUD you're looking at reliably up to 170bhp at 26psi.
Consider this option if you want fast spool combined with respectable power, without the added issue of controlling VNT's. Suited to less-gov shimmed engines than a TD04 as the power band is much lower, wouldn't recommend revving to 6krpm.
Currently running 24psi on the estate, 20psi by 2250rpm, peak boost at 2750rpm. Cruising speeds 4psi at 60mph, 7psi at 70mph.
DO NOT overspeed or dewastegate these as they have a habit of snapping shafts, my last one went at about 34psi. Keep it sensible, it's more fragile than the seemingly bombproof T25 and TD04, however spools FAR quicker.
The holset 200wg, which is from what I gather what used to be the he211w, would be a much better option. If you have instant boost along with your EGT condition, then that turbo is a restriction at max rpm.
#9
by
on 02 Jun, 2014 08:12
gt2056 is a good turbo and flows 27lbs min, but at 45 psi it is highly ineffecient which probably has a lot to do with the super high egt's
what intake manifold do you currently have?
#10
by
on 02 Jun, 2014 13:48
I figured the number of 16lbs/min I had were off as the T3 would do that much, but I couldn't find much of anything on them. Even at 27lb/min the littler holset flows 32lbs/min IIRC and would still be efficient at his boost levels.
But as I said, if you want it to last you probably should change some hard parts. No need for a custom exhaust manifold if you cant get it out of the 2" exhaust. I also am curious about what intake you are running.
#11
by
chiefdiesel
on 02 Jun, 2014 17:42
Thanks for in input everyone. This is a "mock" setup. The intake is made by Spearco, an aluminum part from an aftermarket turbo kit for the NA 1.6 diesel. The exhaust manifold is very similar to the stock cast gasser type made to accept the turbo. The exhaust is crimp bend restrictive. My goal is to upgrade the components around the pump. I will not push the engine to the limits.
#12
by
chiefdiesel
on 02 Jun, 2014 17:53
@ Rabbitjockey: I requested the cutoff @4k because there is little to gain after that. The boost valve has not been set also. Keep in mind that I'm in the test and tune stage. Also, it takes fuel to make boost!
#13
by
on 02 Jun, 2014 18:02
I just looked at your sig line and saw .216 nozzles on top of all the other stuff. If you want to make power you should get at least the .260 or .275 nozzles.
That much boost on a GT 2056 will look like this if you don't take it down...
#14
by
chiefdiesel
on 02 Jun, 2014 18:07
I need to update that sig. I have a set of R520
