TDI Engine -General Info
Extrudeahone Intake Polishing
Topic: Extrudeahone Intake Polishing (Read 6649 times)
May 10, 2014, 07:37:02 am
GEE-BEE
May 10, 2014, 07:37:02 am »
Sending in another PD150 intake for polishing
http://extrudehoneafm.com/
Iam having the headwork done also on this ALU build this will match the intake..
Justin at greaseworks got one that was done and its first time he had seen this process or quality
We do this on all the Allison / Rolls Royce turboshaft helicopter intakes assys
GB
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
May 16, 2014, 10:35:47 pm
TimpanogosSlim
Pretty dumb for a smart guy
Re: Extrudeahone Intake Polishing
May 16, 2014, 10:35:47 pm »
interesting approach. I don't doubt that it works, to a point.
"polishing" though turns out to be a dead end in performance. dimpling, like a golf ball, it turns out, increases the velocity of fluid transfer (air is a fluid) by creating small tight pockets of high compression which have a 'surface' far smoother than any solid material.
this has even been applied to aircraft fuselage paint, which now has an irregularly mottled surface. They tried giving it a regular surface, but it tuns out that the irregular surfaces perform better over-all by discouraging the formation of resonances and standing waves.
still, this must beat the heck out of sitting at a work bench with a burr.
May 16, 2014, 11:48:56 pm
May 16, 2014, 11:48:56 pm »
Generalizations like hat can land you in a lot of trouble. fluid dynamics is a complicated thing.
Finish is adjustable by varying grit size.
May 17, 2014, 09:45:12 pm
GEE-BEE
May 17, 2014, 09:45:12 pm »
I have a PD130 & Pd150 inbound from Europe..
One will have it , one wont, your welcome to put them on a flow bench if you wish..
Giles Pump OHC
MK1 JETTA DASH
May 18, 2014, 03:11:03 pm
sdubfid
May 18, 2014, 03:11:03 pm »
gee-bee you should make a build thread, its hard to keep track of 20 different posts
May 19, 2014, 07:54:31 pm
GEE-BEE
May 19, 2014, 07:54:31 pm »
I am just posting info...
Sometimes Iam really sorry I do
Giles Pump OHC
MK1 JETTA DASH
May 21, 2014, 07:01:40 am
May 21, 2014, 07:01:40 am »
Quote from: GEE-BEE on May 19, 2014, 07:54:31 pm
keep it up i enjoy it ;^P
May 22, 2014, 08:44:43 pm
G60ING
Corrado TDI
May 22, 2014, 08:44:43 pm »
I bolted an extrude hone head and intake manifold on a Lysholmed g60 of a friend and saw 30+whp increase and no drop in psi. I would love to send a TDI head and manifold to them.
May 22, 2014, 08:50:57 pm
G60ING
Corrado TDI
May 22, 2014, 08:50:57 pm »
I'd post pics but it's complicated on this forum
May 23, 2014, 07:44:30 am
GEE-BEE
May 23, 2014, 07:44:30 am »
Justin at Greaseworks had the same results....
I rest my case..
Giles Pump OHC
MK1 JETTA DASH
June 01, 2014, 07:39:06 pm
chiefdiesel
User+
June 01, 2014, 07:39:06 pm »
A few years ago, I sent a set of ALH auto nozzles to them for larger holes. I think they were enlarged to .216. They worked great and the cost was about $100 and a sheet was included showing the calibration of the flow.
2 B4 Passats Ecodes/HID/pp764/rc2
'85 Jetta coupe 1.6 n/a
'80 Caddy 110 (afn) m-tdi/12mm Lt 2.8 ip/.216/fmic
