TDI Engine -General Info
Another exhaust manifold
Topic: Another exhaust manifold (Read 5022 times)
May 03, 2014, 09:07:03 am
GEE-BEE
May 03, 2014, 09:07:03 am »
http://www.darksidedevelopments.co.uk/products/tubular-top-mounted-manifold-for-1-9-tdi-with-gtb-turbocharger.html
I was going thru there webste for a well made race pipe for my alu/ pd130 install
GB
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
May 03, 2014, 04:35:20 pm
Syncroincity
Re: Another exhaust manifold
May 03, 2014, 04:35:20 pm »
*Add to Wishlist*
Wow. Nice piece, obviously quality. $1265 at today's exchange rate.
plus shipping from UK. Yikes.
What turbo is this designed for? This would be a nice unit for a 50-degree Vanagon because of the top-mount position, lifts it up out of the mud a little.
JC McCavitt
'86 Syncro GL Camper AAZ
'98 Jetta Wolfie
'04 Passat Variant GLS 4Mo 5MT
May 03, 2014, 06:54:09 pm
Re:
May 03, 2014, 06:54:09 pm »
It'll be for the GTB series turbos, which are totally awesome.
You'd be surprised how reasonable shipping can be. Ryan at Darkside sells a lot to North America so he has things pretty dialed.
May 03, 2014, 06:56:54 pm
May 03, 2014, 06:56:54 pm »
id buy a tig to build my own vs that price... glad i own one..
May 03, 2014, 06:59:40 pm
GEE-BEE
May 03, 2014, 06:59:40 pm »
heres the turbo spec
http://www.darksidedevelopments.co.uk/products/garrett-gtb2260vk-gtb2056vk-and-gtb1756vk-turbocharger-with-vacuum-conversion.html
230hp at 31psi
its a buy for me..
Now to talk to Giles..
GB
Giles Pump OHC
MK1 JETTA DASH
May 03, 2014, 09:00:44 pm
Re:
May 03, 2014, 09:00:44 pm »
That's the GTB1756VK, same as I'm using. Great turbo!
May 04, 2014, 06:33:12 am
GEE-BEE
May 04, 2014, 06:33:12 am »
Is your turbo Electonic or Vac setup
Where did your purchase the turbo from..
Giles Pump OHC
MK1 JETTA DASH
May 04, 2014, 09:45:21 am
Re:
May 04, 2014, 09:45:21 am »
Mine is vacuum. I got it from a seller on TDIclub called X-Man. It is a rebuild but comes with its VSR balance sheet and everything.
May 04, 2014, 12:54:44 pm
GEE-BEE
May 04, 2014, 12:54:44 pm »
Thanx
I will email Ryan and get the manifold and the Turbo
I will get a downpipe flange and have techtonicstuning make the MK1 tall 2.5 downpipe..
GB
Giles Pump OHC
MK1 JETTA DASH
May 07, 2014, 09:14:57 pm
GEE-BEE
May 07, 2014, 09:14:57 pm »
Ordered today !
I purchased the exhaust flange to make the downpipe from...
Will see...
Giles Pump OHC
MK1 JETTA DASH
